Results 1 to 4 of 4
Thread: Quick & Dirty SawStop Outfeed Table
    I will one day build a proper outfeed table, one that hinges up and down, but for now this worked out really well.
    I'm cutting up a bunch of parts to make some small carts for the L shop, using a roller stand is not really the answer for this, but I needed something, as the balancing act at the edge of the tablesaw is not a good thing.
    I used the piece of laminate covered board that I cut off the extension table of the SawStop when I downsized it.
    It is very simple. I cut a piece of wood to support the outfeed table, and I put some threaded inserts into the wood, these line up with the holes in the back angle iron rail on the saw. I then use two bolts with knobs on them to tighten down the outfeed table, that holds the end on the saw..
    The end away from the saw, I just use one of my roller stands to hold it up.
    A pic showing under the saw so you can see the simple way it is attached.
    A shot from the other side.
    To make it easier to line up the holes in the angle iron and the inserts in the wood, I just drew a line on the angle iron, even I should be able to figure it out, without having to crawl under the saw!
    Remove the two bolts by hand and that is all I have to do.
    The roller stand is just sitting there, not attached in any way.
    When I'm done, the outfeed table just goes under the back of the saw, and a simple wedge holds it there, out of the way until I need it next time.
    Simple, effective, cheap and quick to build!
    10,604
    That will get it done
    Constantine, MI
    7,890
    My thoughts exactly.
    www.wrworkshop.com
    Los Angeles, CA
    2,668
    good solution for a small shop.
  1. Quick and Dirty Drum Sander Stand
    By Vaughn McMillan in forum Flatwork Project Showcase
    Last Post: 10-12-2011, 11:53 PM
  2. Outfeed table help, please
    By Jonathan Shively in forum General Woodworking Q&A
    Last Post: 01-05-2010, 09:27 PM
  3. Quick & Dirty
    By Ron Roase in forum Flatwork Project Showcase
    Last Post: 11-19-2007, 09:13 AM
  4. Project: Outfeed Table
    By Matt Meiser in forum Jigs and Fixtures
    Last Post: 03-10-2007, 07:49 AM
  5. Show Me Your TS Outfeed Table!!!
    By Rob Bodenschatz in forum Jigs and Fixtures
    Last Post: 02-27-2007, 10:55 PM
