Results 1 to 10 of 22
Thread: Rust removal???????
    Floydada, Tx
    1,941
    Rust removal???????
    I just received a 197_? Rockwell 10" BS and it needs a lot of tlc. Cost for this bs, help rebuild a entertainment center. 1 peice of red oak 4/4x 6"x 3' and about three hours helping my buddy do this. I was suprised by the amount of plastic on this thing wheel covers and wheels are all plastic. The table has alot of rust(no major pitting). My idea was to remove it and use electrolises( sorry about the spelling) to remove the rust. Does anyone know the proper way to do this? I have a heavy duty battery charger 6,12 and 24 volt setting and up to 300 amps. I just need to know what if anything need to be added to the water and how many amps are perfferd for this use. Sorry for the bad pics.
    11,697
    Enjoy the project.
    Check out this link: http://www.bhi.co.uk/hints/rust.htm
    Floydada, Tx
    1,941
    Frank, Thanks for the link. I have to call sufolk on monday to order a new blade. Hopefully this wont take to long to get it going. Sat for 5years.
    Al, here is another site to check out.
    Cleaning with electricity.
    Charlotte, NC
    1,487
    Checkout Stu's drill press rehab thread.
    Arena, Wisconsin
    231
    Quote Originally Posted by Ed Nelson View Post
    Yes Al, as well as threads by Jeff Horton, the Grand Master of Metal Tickling, also known as electrolysis.
    15,582
    Al the electrolysis really works well, and with the battery charger you have, you will be done in no time at all!
    Here is the Kermit Thread
    The Heart of Dixie
    4,265
    Lots of information on electrolysis on the web and some on here. I have meant to do a write up on it and just never have. Stu covered it pretty well.
    Looking at your table, I wouldn't bother setting up a tank. Many people cringe at what I am about to say but I have done it on many cast iron table tops. I take my Random Orbital sander and start with 80 grit cleaning the top. And thats it!
    The rust or the cast iron dust or something in air combines with the 80 grit after just a couple of minutes and it start to removed rust and polish the top. It will leave it smooth as a babies bottom. It will not look shiny and new in most cases. It leaves a patina which I prefer on old machines. Keeps them looking like old machines. If you want shiny new, just keep changing out disks and work your way through the grits. With something as small as that top in way less than a hour you can have it good shape.
    Jeff
    Custom built boats and Kits
    Floydada, Tx
    1,941
    Thanks everyone for the help. I think I will try sanding it as jeff stated and see how it comes out.
    Stu, I will try your method on some of the other parts I have that need cleaning. I really enjoy the way you used the lathe to clean the shafts.
    Ken, Thanks for the link. I will add it to my list of info sites to read up on.
    Al
    Richard Smith Guest
    The milling marks, pores and what ever irreglarities in the surface will retain rust. A table saw is too big to go in a tank. Is there a chemical means of derusting?
  1. Laser Rust Removal....
    By Stuart Ablett in forum Old Iron
    Last Post: 03-22-2016, 04:13 PM
  2. Fretboard Removal??
    By Dan Mooney in forum All Things Musical
    Last Post: 05-24-2015, 11:49 AM
  3. Rust removal
    By Carol Reed in forum Old Iron
    Last Post: 08-16-2014, 04:33 AM
  4. Dado shim removal
    By Rennie Heuer in forum Tips and Tutorials
    Last Post: 03-18-2014, 11:04 PM
  5. rust removal tutorial
    By Frank Fusco in forum Old Iron
    Last Post: 01-28-2007, 12:29 AM
