allen levine
- new york city burbs
I was thrilled with the drawer fronts, they looked fine.
The slides are working fine, without wax, but they will be waxed.
the second coat of oil was still uneven, seems this mahogany really likes to drink oil, so I gave it another coat, this time rubbed on. The pictures seem to have a white haze over the finish, its still wet oil and the bright light above.
The carcass still has to be sanded down with 400 grit and re oiled, then resanded, then one coat of gloss sanded down, then buffed a bit.
The pulls presented me with so many headaches I really dont want to talk much about them. From the time I routed the edges and saw how delicate a sharp edge would be, some chipping off, I knew they were going to be headaches.( Im not using the best router bits ofcourse, since my collection is so poor and alot of them I dont even know what brand they are)
I was about to go to plan B, which was a walnut plate with brass colored pulls, but my wife was thrilled with the pulls and said Im just way to picky.
I know shes being nice. Its a nice look, but the execution of installing the pulls went sour on me. I jigged it out. I clamped and jigged everything.
Ive installed at least 350-400 pulls/knobs, and never had one come out poor enough I had to rethink it.
Dont know what happenned. I thought it would be as simple as other wood pulls Ive installed with just wood screws, but this turned out to be my worst nightmare. The bottom pull as seen in some of the pics, I completely drilled through and had to patch it up.
I drilled wrong holes through one drawer front so off I had to patch it up also.(it wont be seen in back of pulls or if I junk this pull and put walnut plates and go with metal pulls)
Pull 3 and 4 came out a bit misaligned, again, I dont know why, it just moved when I attached them, the jig was the same for all six.
Anyway, the slight repair work I did on the dovetails are fine, there were two bad holes from when I placed the side walls on a dirty work surface, and they were dented, the dark walls help hide it a bit. I was hesitant to work too much on the spots because I figured Id mess it all up a bit more than it was already messed up.
So Im still taking batting practice in the minors, but I didnt let the pulls get me down. IM off that horrible medicine that kept me a prisoner for a month, and Ive dropped almost 30 lbs and feel pretty darn good.
Unfortunately, my health issues are directly related to my woodworking, cause it dictates how much I can do, and my nurse, suprisingly, is coming tomorrow to start my therapy, so the unit will have to sit until Wed or Friday.
Ill make the decision about the pulls by then. Im not sure if I can take my wifes word, she thinks everything I make is top notch.(blind love)
After this build, I can understand why high quality veneered plywood and metal pulls are the first choice for alot of cabinet makers.
and one other note while IM posting this long post-I want to thank those who had enough confidence in me to be a moderator, Ill do my best, but Im not going to post about my builds any less.
