Results 1 to 10 of 23
Thread: What is proper electrical switch and outlet height?
    May 2009
    Lafayette, Indiana
    2,380
    So now that my new shop building is in place, I need to get it wired up. I went out and purchased switches, outlets and boxes. When researching online tonight about the proper height to mount everything I was surprised to find out that there really is no "standard" height. I want my wall outlets to be about mid way up the wall but have found heights mentioned anywhere between 32 and 56 inches. I thought there would be more of a standard.
    Oct 2007
    Indianola, Ia about 12 miles south of Des Moines
    440
    Most of mine are 48" to the top of the box.
    13,440
    Light switches are 48" to the top of the box. Plugs are normally minimum 12" to to bottom of the box (15" for ADA), but 40" (counter height if upper cabinets installed) and 48" are also common. For a shop I'd probably do the 48" height all around.
    Don't think you have any sinks, but within 6' of water need to be GFIC. Any circuits on the outside need to be tied to GFIC also.
    Tom,
    If you have a building code to meet, call the inspection office.
    When I built my shop, because it's a stand alone shop there were no requirments so I placed my outlets 52" above the floor. I can stand a sheet of plywood against the wall without blocking access to my outlets.
    Ken
    North West Indiana
    6,098
    Quote Originally Posted by Ken Fitzgerald View Post
    Tom,
    Now that is a great idea!
    Jon
    30,014
    Ken beat me to it, but for a shop, I've seen it recommended that you put at least some of the outlets high enough that you can lean a sheet of plywood horizontally under the outlet.
    But if your're building to a specific code, he's also right about checking with any local code enforcement folks to see if they have any hard and fast rules.
    Thomasville, GA
    5,992
    I placed most of my duplex outlets at a height of 50" to the bottom of the box, so sheet goods can be placed beneath them.
    Bill Arnold
    Apache Junction, AZ
    26
    I also put several in the ceiling,
    May 2008
    Deming, NM
    42
    Tom,
    The proper place is wherever you think they should be. I just finished up a new workshop that we are getting ready to move into, and mine are 42" to the bottom of the box. My shop cabinets and workbenches are between 34 and 36" high, and I wanted the outlets just higher than them, so it is easy to plug things into without bending down to the floor or finding them behind a cabinet. My inspector never even mentioned it…
    Jun 2007
    4,944
    I have been very thankful that I have several outlets in the ceiling.
    Enjoy,
    JimB
    VOTING MEMBER
  1. Switch Hitter vs Switch Pitcher
    Last Post: 06-17-2011, 12:53 PM
  2. Table saw to dryer outlet troubles/Please help!!
    By Craig Johnson in forum New Tools
    Last Post: 11-26-2008, 09:26 PM
  3. What 220vac outlet/plugs do you use?
    By Grant Vanbokklen in forum General Woodworking Q&A
    Last Post: 09-11-2008, 02:25 AM
  4. Outlet Boxes - Metal or Plastic?
    By glenn bradley in forum Carpentry and Construction
    Last Post: 10-02-2007, 05:07 PM
  5. Proper technique for wiring 220 outlet?
    By Wes Billups in forum Carpentry and Construction
    Last Post: 02-15-2007, 02:59 AM
