Gary Zimmel
- Stony Plain, Alberta
Rails & Stiles.
As I have these two lower carcasses on the assembly table I thought I may as well make the doors for them.
Last night I machined a few pieces to close to thicknes and let them sit overnight.
I'm sure they will move just a tad so after 24 hours I machined them to final thickness.
After all the pieces have been ripped to size I shoot one end .
Then a quick trip to cut all to the right length and then clean that end up on my shooting board. Only takes a couple quick licks with the #9.
If I remember Glenn B uses his router table for his grooves and tenons.
I just use my table saw.
Push it though one way and then the other. This ensures the groove is in the middle. For doors I go 3/8" deep.
My tenons are also made on my table saw.
Quick little test block to get the right height and depth.
This is the joint we are looking for.
Nice and tight line. Tenon goes in easily and does not have to be forced.
But will not just slip out. Fine line between to tight and too loose....
The last thing I do is take all the parts to my bench again
Here I spend a couple of minutes cleaning up the edges.
Even with sharp blades and a shelix head in the jointer it is amazing what a couple quick stokes will do with a hand plane.
Most time I will use my 4 1/2 for this.
And after a hour we have the parts for a couple of doors.
Nice leisurely evening in the shop...
Next time we will do the flat panels for these two doors.
