Results 1 to 10 of 15
Thread: Semi-frozen Morse 2
    Jun 2007
    4,944
    Semi-frozen Morse 2
    Hi,
    I have a Delta 46-460 lathe. The center is quite difficult to remove from the tailstock. If I use the knock out bar, it just knocks out the central attachment leaving the revolving center in the Morse 2 of the tailstock.
    If I use a wood block on the back of the bearing and hit it with a hammer, nothing happens. If I use a half inch dia. steel bar and hit it with a mallet, nothing happens. If I hit the steel bar with a ball pein hammer a few times, it will come out.
    A less radical method of removal would be appreciated.
    Thanks and Enjoy,
    JimB
    VOTING MEMBER
    North West Indiana
    6,097
    Jim, how often are you removing the item? If I leave the spur drives in the headstock of my mini lathes in the school shop over summer, I encounter the same situation you talk about. Once I knock them loose and students are taking them out and putting them in daily, this issue disappears. Maybe when done for the day, take the spur drive or whatever is the issue out?
    Jon
    30,002
    Jon, I think it's the live center that's stuck in the tailstock.
    Jim, most tailstocks these days have a self-ejecting quill. You should be able to turn the handle counter clockwise to the point where the quill is pulled all the way into the tailstock. Then turn it a little more, and the live center should come out. If you have really jammed the live center into the quill, it may take a fair amount of force, but you should be able to do it with the handwheel alone.
    From the User's Manual:
    Quote Originally Posted by 46-460 User's Manual
    REMOVING THE LIVE CENTER
    To eject the live center (F) Fig. 9, turn tailstock crank (P) Fig. 8 counterclockwise to retract the quill. As quill retracts, the live center contacts an internal ejecting pin. When it does, you will feel the crank get harder to turn. Turning further past this point loosens the live center for
    easy removal.
    If it's difficult to get the live center out that way, it's an indication that you're cranking it down too hard onto your workpieces. (That can be hard on the headstock bearings.) If the spur center is well-seated into the wood, you shouldn't need more than firm pressure from the tailstock to keep a piece on the lathe. I often make an "X" with a chisel for the spurs of the spur center to engage with. Actually, I do these steps:
    1. Use a mallet to lightly tap the spur center into the spot on the wood where I want it to go. This is just to mark the "X" where the spurs hit the wood.
    2. Remove the spur center and using the "X" mark it just made, take a 1" bench chisel (I use an old beater with a broken plastic handle), and give it a good whack or two in each half of the "X" to deepen it.
    3. Put the spur center back in place on the wood, aligned with the newly-deepened "X", and drive it firmly into the workpiece with a mallet.
    4. Then mount it on the lathe.
    5. Turn, turn, turn.
    Jim,
    as Vaughn stated.....most are self-ejecting but.....
    tighten the lock on the quill....then unlock it but don't turn the lock handle more than 1/2 a turn when you do. Then back the quill out and see if it will self-eject.
    On mine, when you unlock the quill, if you turn the locking lever/knob more than 1 turn or so, it will not auto-eject the center....
    Ken
    North West Indiana
    6,097
    That is what I get for not comprehending what it was I was reading! Eyes contacted the fingers before turning on the brain. My brains have begun to leak!!
    Disregard my post Jim and go straight to Vaughn's. Yep, self ejecting.
    Jon
    May 2011
    Cape Cod, Ma.
    1,553
    Dont feel bad Jonathan, I did the same thing a few weeks ago. completely forgot about the self eject feature and was pounding away with a mallet and the brass knock out rod...... I figured mine out accidentally when I cranked tail stock all the way and the live center just popped out.....
    11,825
    My first thought was the inside needs a good cleaning.
    Remember Tod's technique for permantely installing the chuck into a drill press that has an M2: spit on quill, insert and leave alone for a while.
    Works.
    For easy removal they need to be clean.
    That is some good advice I just learned.........thanks
    Anybody can become a woodworker, but only a Craftsmen can hide his mistakes!
    The Bible tells us to love our neighbors, and also to love our enemies; probably because they are generally the same people.
    Jun 2007
    4,944
    Removing stuck Morse 2
    Thank You All,
    Jon, I have not turned a bowl for a couple months. I did not remove the spur nor the revolving center from the lathe during that time. I just did spindle work. The spur came out with just a slight extra pressure. The problem was on the tailstock end. No, the self-eject did not eject.
    Vaughn, I turned the knob as hard as I though prudent. It was like turning a bolt into a steel plate; it felt like that was the absolute end.
    Ken, thanks for your info. I normally spin the the lock lever a rotation or two. I will try to be less exuberant.
    Frank, I clean the Morse 2 tenon and mortise parts each time I change things. My shop may not be neat, however, I tend to be very clean with machine parts.
    Thanks Again Guys (No gals replied. Maybe I should shower more often.) (Just kidding. I am a very clean person.)
    Enjoy,
    JimB
    VOTING MEMBER
    3,134
    Quote Originally Posted by Jim C Bradley View Post
    Thank You All,
    Enjoy,
    JimB
    Sniff sniff sniff hmmm must be the brains....
  1. Damage Inside Morse Taper #2
    Last Post: 12-28-2012, 06:48 PM
  2. Morse Code in the Sand of Mars
    Last Post: 10-15-2012, 11:38 PM
  3. FS Wood RIver Pen mandrel for #1 morse taper $14.99
    By Ned Bulken in forum Classified Ads
    Last Post: 08-27-2012, 02:00 AM
  4. Morse/McMaster Carr bandsaw blades
    Last Post: 02-26-2011, 04:52 PM
  5. loose morse taper
    By gary doby in forum Turning Tool Questions and Show & Tell
    Last Post: 01-09-2008, 02:27 AM
