Results 1 to 6 of 6
Thread: Battery Pack Re-purpose
    Dec 2008
    Portland, Oregon
    1,898
    My wife works for a local charity and when they do fund raisers and such, they have an electronic picture frame that they use for a slideshow to show what goes on at the charity.
    The frame came with the standard little powerblock that plugs into the wall, but they don't always have a convienant outlet and wanted a battery option. couldn't find anything available.
    I went to Sears and got a 12volt Lithium Ion Battery and charger and came up with this. It runs the screen for about a hour.
    Attached Thumbnails Attached Thumbnails BatPack.001.jpg   BatPack.002.jpg   BatPack.003.jpg   BatPack.004.jpg
    Jesus was a Woodworker
    10,600
    That's ingenious
    May 2011
    Cape Cod, Ma.
    1,553
    Wow! Great idea!
    Orem, Utah
    935
    Details ... we need details!
    Two-piece construction? Recess was template routed through the upper piece?
    However you did it ... great job on the alignment. And a great idea in the first place!
    Thomasville, GA
    5,987
    Great idea and execution, Dan!
    Bill Arnold
    Dec 2008
    Portland, Oregon
    1,898
    Quote Originally Posted by Kerry Burton View Post
    Two-piece construction? Recess was template routed through the upper piece?:
    2 Pieces of 1" thick Mahogany, I cut it out on a scroll saw and fine tuned it on the oscillating spindle sander.
    I made the top slightly bigger than the bottom, once I got the holes aligned and drilled in the bottom for the terminals, I glued the two halves together using the battery itself to keep everything in line, and after it dried I trimmed the sides flush.
    I routed a groove in the bottom for the wires and LOML is going to cover the bottom with felt or something similar.
  1. Problem with the Craftsman C3 19.2 volt Lithium-Ion Battery Pack
    By Joseph Crivelli in forum General Woodworking Q&A
    Last Post: 05-06-2010, 01:36 PM
  2. 10" Delta 35-7657 40T General Purpose Blade - $17
    By scott spencer in forum Hot Deals
    Last Post: 10-14-2009, 07:41 AM
  3. Added Purpose for my Marking Gauge
    By Jerry Palmer in forum Neander Tool Questions and Show & Tell
    Last Post: 07-19-2008, 10:34 PM
  4. 50% off Freud HD Multi-Purpose Saw Blade
    By Chris Mire in forum Hot Deals
    Last Post: 04-06-2008, 08:40 AM
