Results 1 to 7 of 7
Thread: Sound Proofing and insulating a workshop
    Cool Sound Proofing and insulating a workshop
    G'Day Folks
    I'm in the process of converting a concrete slab, brick wall, tin skillion roof 2 car garage into a woodshop.
    We have already done some substantial work to this end, (construction of a 10 sm, mezzanine platform for timber storage, construction of working height perimeter benches on 2 walls, framing for an office/storeroom).
    My major concern now, is how best to insulate and possibly soundproof the building (only if necessary with the latter).
    I am a carpenter by trade, and so think i'm pretty useful at construction, (some of the time anyway, that is i know enough to avoid some trouble, sometimes).
    I have also read a few forums threads on this and other forums about soundproofing in particular, and been encouraged and engaged by the inventiveness, of some people in attempting to address these dual problems.
    However like most folks my wallet has rat traps set on them by my good wife, so getting a professional job done is not an option.
    If anybody has any suggestions that i might be able to have a crack at, especially those that might serve the dual purpose of insulation and soundproofing, it would be greatly appreciated.
    Cheers
    Pete Murphy
    30,008
    I'm in the dark about insulating brick walls, short of building a sheetrock or other type of wall over them with insulation in between the inner and outer walls. Pretty much any thermal insulation you add will also help deaden the sound. You can get real involved with soundproofing things, but it can also get pretty expensive, too. Are you primarily looking for thermal insulation or sound insulation?
    My shop is a double car garage, frame and stucco exterior, with sheetrock on the walls and ceiling. I don't know if the walls are insulated, since it was this way when we bought it. I know the ceiling is not. My un-insulated metal double wide overhead door is the prime heating and cooling thief, and that's also where most of the noise gets out.
    But despite the metal garage door, my immediate neighbors have repeatedly told me that they can't hear any of my shop noises when they are inside their houses, and if they're in their yards, it's so faint it's likely to be drowned out by their own TV or stereo, or other city noises. (We live at the end of a cul-de-sac, and a couple of these neighbors wouldn't hesitate to complain about something like that. They're not shy about making their feelings known about the local goings-on.) I try to limit the real noisy stuff like running the planer or router table to no later than 9:00 PM or so, but I'll go all night long with the DC, the air compressor, the pneumatic sander all running at the same time, and the boom box blasting out tunes trying to keep up. Yet the neighbors insist they don't hear anything. And I do ask periodically to make sure.
    My point in saying all this is unless you specifically know of a noise issue you need to address, I'd just seek out the most economical thermal insulation approach and not worry too much about the sound.
    NH
    4,005
    Strap with 2 x 3's and spray foam.
    Stupid hurts.
    10,604
    Or maybe strap your brick walls with "Z" furring and use rigid foam panels.
    and, Welcome !!!
    3,134
    I think you jumped to soon building the benches, insulation should come first.
    Out of curiosity how did you decide what you needed for benches?
    Jun 2007
    4,944
    Hi,
    I have posted, in more detail, in other threads about my shop and sound.
    Basically:
    1 Nearest neighbor to shop 32 feet as I remember. Whatever is in other posts is correct. However 32 is right on or very close.
    2 No insulation above or in wall closest to neighbor.
    3 No insulation on the two eight-foot wide car doors or the wall where a 3rd car door would normally be.
    4 I have a one-man shop (unless Glenn is here). So my maximum machinery run at any one time is the Dust Collector and one machine. The DC, thickness planer and TS are my biggest noise makers.
    5 The neighbors say that they cannot hear my equipment when they are in the house. If they are out on the patio they say that they can hear it. However, it is so faint, that it is absolutely no problem. Noisy cars or motorcycles on the street or barking dogs (I don't have any) are a problem.
    6 I very rarely run noisy machinery before 9:00 am or after 9:00 pm. I would not hesitate to do so if I really needed to do so.
    Enjoy,
    JimB
    VOTING MEMBER
    If you look at >> this page << that is what I did to the wall between my two daughters bedrooms, and it worked VERY well indeed.
    There is also a product called QuietRock that I have heard works well.
  1. New Sound
    By Vaughn McMillan in forum All Things Musical
    Last Post: 01-15-2014, 04:41 AM
  2. Insulating a Basement?
    By David Agnew in forum Carpentry and Construction
    Last Post: 07-23-2012, 10:01 PM
  3. Insulating a shop
    By Tom Baugues in forum Carpentry and Construction
    Last Post: 10-12-2011, 02:44 AM
  4. ? on sound editing
    Last Post: 01-14-2008, 05:57 AM
  5. Insulating a cantalevered bump out
    By Mike Gabbay in forum Carpentry and Construction
    Last Post: 12-03-2007, 05:52 PM
