Results 1 to 10 of 17
Thread: Keepsake Box
    Sep 2007
    Bloomington MN USA
    268
    Keepsake Box
    Well here we go again with yet another box. This one however is a little different as there is no hardware and yet it has a levered top with a secret compartment. It is made of Red Oak & Walnut, and it is 8 inches wide and 12 inches long and 7 1/2" high. I am attempting to take pictures durring the build, but am not the best with a camera so ...... I started out with a piece of oak 7 1/4" x 42" And layed it out so as the grain would follow around the box and began cutting them all to length.
    Next I lmarked out where the holes were to be drilled and did that at the drill press. This will later form the base.
    Then I put a 45% chamfer on the outer top edge of all 4 pieces at the router table.
    I then set up for datoes and rabbets at the saw table for the bottom and the top.
    I used a japanees saw to cut the angle on one end of the front and back that will make the top move.
    Now it is time to cut all the miters (never really got comfotable with this) so I used my slede and a stop. I cut a 45% one end of each piece first, then set up a stop block and cut the other end so both pieces will be a good match for length.
    I then cut out the bottom and did a dry fit, it looks good so on to glue.
    Next I did the cut out at the band saw for the base and sanded all the inside parts of the box as now is the best and last time to do that.
    Now ready for the glue up, I always like to rub glue on with my finger on the end grain and let it set up then do the regular glue up as end grain sucks it up like a spong and I think you get a stronger joint. I also put some tape on the inside corners to eliminate glue squeese out.
    Now with the help of some more tape I fold up the box sides and slip in the bottom. Add a couple of band clamps to ensure all mitters are tight.
    Now all I can do is wait for the glue to dry and cut out the piece for the top from a piece 3/4" walnut. Will return soon with more.
    If you make a mistake it was part of the original plan!
    30,014
    Very cool, Ron. I like the foot details, too. Thanks for going to the trouble to take the photos along the way.
    17,472
    yeah thanks ron now are you done yet the popcorn is all gone and am waiting to see the rest of the show
    Los Angeles, CA
    2,668
    Thanks for the step-by step photos. Easier for a novice like me to learn this way.
    10,604
    Looking forward to seeing how you do the top and secret compartment
    Orem, Utah
    935
    The design looks a lot like the one in the latest issue of HANDY magazine. Am I right?
    Sep 2007
    Bloomington MN USA
    268
    Right On Kerry, It just looked like a nice project to do. I always give away most all my boxes as LOML says we only have just so much room for display around here
    Really nice work...I am going to file this one away for a free weekend! Thanks for sharing
    Anybody can become a woodworker, but only a Craftsmen can hide his mistakes!
    The Bible tells us to love our neighbors, and also to love our enemies; probably because they are generally the same people.
    Jun 2007
    4,944
    That is a nice box. I like the way you did the "feet" so that there is no interruption in texture or grain pattern.
    I'm like Larry, waiting for the next part of the show.
    Thanks for showing.
    Enjoy,
    JimB
    VOTING MEMBER
    Sep 2007
    Bloomington MN USA
    268
    Well now that the glue is set up and I have one of many trips out after all the leaves that keep falling, seems like every year there are more ... mabe Im just getting older. Anyway now I have cut out the parts for the false bottom.
    Now I can cut the slots for the keys, 4 in each corner so sixteen of those little keys to be sliced of what was left from the top.
    Now that these are all in just a couple of hours drying time and I can finish sanding the outside of the box.
    I have cut out the top and checked to make sure it is fitting the way I want.
    Now every thing is complete, I put some BLO and shelack along with a coat of wax. Wanted to have a soft look when done.
    By pushing on one end it raises the top up so you can remove it.
Name:	Keepsake Box Lidd lift.JPG
    Then by pushing on the false bottom it also lifts out of the way to reveal a space for all that secret stuff you just don't want any one to find.
Name:	Keepsake Box False Bottom .JPG
    And thats about all the trouble I can get into on this project, except of coarse now I have to find a recipiant for the box. Allin all it was a fun project and I always like doing the small stuff the best cause you can change directions as you go, thats what makes it fun.
  1. small keepsake box
    By John Daugherty in forum Flatwork Project Showcase
    Last Post: 01-20-2015, 05:30 PM
  2. Another Custom Keepsake Box
    By Mike Mathieu in forum Flatwork Project Showcase
    Last Post: 08-24-2013, 01:19 AM
  3. Keepsake box
    By Ken Cook in forum Flatwork Project Showcase
    Last Post: 08-06-2011, 02:58 PM
  4. Keepsake Box
    By Ron Roase in forum Flatwork Project Showcase
    Last Post: 03-16-2011, 05:15 AM
  5. Keepsake box
    By Bobby McCarley in forum Flatwork Project Showcase
    Last Post: 12-18-2007, 02:23 PM
