Results 1 to 2 of 2
Thread: Open Segmented Bowl Jig
    Jan 2010
    Johnstown, PA
    20
    I made an open segmented bowl jig, from ideas that I got on line. You can see the jig and the first bowl that I made with it (and the problems) at my web site http://dennyedwards.com.
    Los Angeles, CA
    2,668
    I have used a similar jig in the past. It didn't belong to me though.
    I will watch the videos some other time as I am in no mood to install quicktime right now.
    I like this jig because the segments do not slip down after applying the glue, unlike the jigs that are mounted on the lathe perpendicular to the piece. I was working on one open segmented bowl that required me to take the piece off of the jig and true up the face and then re-mount it on the jig. I ended up screwing up the alignment of the segments. Next time I will try the lathe mounted jig.
  1. Segmented bowl that is ... different.
    By David Miller in forum Lathe Project Showcase
    Last Post: 02-15-2014, 04:57 PM
  2. 1st segmented bowl
    Last Post: 11-19-2008, 02:48 PM
  3. Segmented Bowl
    By Bernie Weishapl in forum Lathe Project Showcase
    Last Post: 05-18-2008, 01:18 PM
  4. 12'' segmented bowl
    By Ad de Crom in forum Lathe Project Showcase
    Last Post: 03-03-2008, 01:48 PM
  5. 12'' segmented bowl
    Last Post: 11-29-2007, 08:19 PM
Tags for this Thread
