Results 1 to 10 of 17
Thread: How would you fix this?
    Oliver Springs, TN
    1,190
    A friend at work asked me if I could repair some damage to his daughters bed. His mother gave it to her as a gift when she was little. I'm 99% sure it's maple. How would you make this repair?
    Attached Thumbnails Attached Thumbnails bullet bed 005 (Custom).JPG   bullet bed 006 (Custom).JPG   bullet bed 007 (Custom).JPG   bullet bed 008 (Custom).JPG
    14,477
    do you have the sliver of wood that got split off?
    Oliver Springs, TN
    1,190
    Good question, and I don't. I asked if he had it and he said it's been gone for years.
    May 2011
    Cape Cod, Ma.
    1,191
    your best bet will be to cut in some sort of "dutchman" albeit a very large dutchman. Splice it in such a way as to be as inconspicuous as possible then match the finish.
    You can tell a lot about a person by the jokes that offend them
    Thomasville, GA
    2,152
    This might seem a bit off the wall, but here goes: How about making a cross cut just above the damaged area to a depth equal to the depth of the damage. Remove the remainder of the wood down past the damage with a dado blade on the table saw or with a band saw. Cut a new piece of material to match the area and glue it up. Make a "detail" groove where the new piece meets the old. Next, make a matching detail groove on the other leg, so the repair is less apparent. Matching the finish should be straight forward.
    Bill Arnold - Website - ShopCam
    Food for Thought: The Ark was built by amateurs, the Titanic by professionals.
    Ignorance is only skin deep, but stupid goes all the way to the marrow!
    Live every day like it's your last, but don't forget to stop and smell the roses.
    7,718
    Don't forget to put the 2 steel rods back in to hold the side frame.
    I think that I would use a router to square up the top and rout down to the lowest part of the break then splice in a matching piece.
    Asking a stupid question is better than repairing a stupid mistake.
    Thomasville, GA
    2,152
    ... I think that I would use a router to square up the top and rout down to the lowest part of the break ...
    Bob, that's a much better idea than mine for material removal. All it would take is clamping boards to each side of the leg to act as rails for a router base, then make passes with a straight bit until the area is level.
    Quote Originally Posted by John Daugherty View Post
    if i were doing it...... a large patch as possible but w/o thr cut line to hide or disguise the patch. the patch shows character, the disguise suggests you are hiding something... imho
    one finger typing, please forgive errors.
    7,725
    I'd probably do it as Bob suggested too.
    Ħuʍop ǝpısdn sı ǝuoɥd ɹnoʎ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
    North West Indiana
    4,665
    Holy cow, crossbred critters!!! That's what happens when the bed bugs cross with the termites!!!!!!!
    Remove, level, square and create an area for a patch. Do this to all four legs. Install walnut or some other contrasting wood as a patch. Got to have some bling on this bed!
    God and family, the rest is icing on the cake.
    I'm so far behind, I think I'm in first place.
    Premier Bovine Scatologist
