Results 1 to 10 of 28
Thread: Christmas Bell
    Goodland, Kansas
    4,834
    Christmas Bell
    Well my grandson and granddaughter saw a bell made by a friend of mine Curt Fuller and thought they would like to have one. So found some scrap 3/4" thick by 3" wide cherry and a scrap piece of 1/8" purple heart. I sandwiched the purple heart between two 14" pieces of cherry. I made my cuts at 30 degrees like a pie wedge. The six pieces are glued 1/2 or 3 pieces at a time. Then the halves are glued. Once dry then turn the bell. Used a 4" belt sander to make sure I had a tight fit when gluing the halves together. Not as good as Curt's but I am satisfied with it. The cutting has to be pretty precise. I have a half dozen more glued up and will pick the best for them. Hopefully my glue joints will be a little better on the next batch. It is sanded to 320 grit and finished with 7 light coats of GF Woodturners finish. It took about 45 minutes to apply the 7 coats. I cheated and used a hair dryer which each coat took about 5 minutes or so applied with a piece of old T-shirt. Turned this morning and finish on by lunch.
    Attached Thumbnails Attached Thumbnails Cherry purpleheart Bell 1.jpg   Cherry purpleheart Bell 2.jpg
    Bernie W.
    3,132
    Bernie i seen Curts and yours does him justice. good jod man.
    566
    That looks great, Bernie.
    I would like to share a finishing technique I just learned from a friend for small items like your bell or globe ornaments.
    He uses triple thick Krylon Clear Glaze and sprays on 10-15 coats with the piece hanging in a dust free environment.
    After 24 hours he lightly sands the lacquered finish with 800 or 1200 grit. Then he uses Nu Finish Clear Coat Scratch Remover to remove all the scratches by rubbing on a coat and rubbing it off with a paper towel.
    Then he uses Nu Finish Once a Year Car Polish as a top coat. Rub on a coat, allow to dry and buff off with a soft cloth.
    It is a remarkable finish and as the old commercial used to say, "I can see myself" when you get done.
    He uses it on all his hollow globe ornaments and it really puts a shine on it.
    I may be getting a little older physically but mentally I'm still tarp as a shack.
    Thomasville, GA
    5,998
    That's a fine looking bell, Bernie!
    Bill Arnold
    13,451
    Great looking bell Bernie!
    To a small child, the perfect granddad is unafraid of big dogs and fierce storms but absolutely terrified of the word boo. Robert Brault
    Goodland, Kansas
    4,834
    Thanks everyone.
    Mike that finish technique sounds interesting. I will see about giving that a try. People around here like shiney. I can't hardly sell a matte, satin, or semi-gloss finished item.
    Bernie W.
    Nov 2007
    Salt Spring Island, BC Canada
    2,070
    Be interested in some pics of the process Bernie. looks like a fun project.
    Jun 2007
    4,944
    Bernie,
    I like your bell.
    The junction lines you are concerned about won't be seen if the bell is hanging on a tree or in a window. If it will get a lot of "up close" viewing, a very small, "V" type groove down each seam will make the glue joint disappear. DAMHIKT.
    Enjoy,
    JimB
    VOTING MEMBER
    30,017
    Nicely done, Bernie. I may have to try something like that. Curt makes it look easy, huh?
    Jun 2007
    Kirkintilloch, Scotland.
    230
    Lovely looking bell Bernie your grandchildren will be pleased with it
    "Every day's a school day"
  1. another bell and my first bowl
    By dave worrall in forum Lathe Project Showcase
    Last Post: 05-16-2015, 08:28 PM
  2. small bell
    Last Post: 02-03-2015, 04:21 PM
  3. Old school bell.....
    By Larry Edgerton in forum Off Topic Discussion
    Last Post: 02-27-2011, 08:59 PM
  4. new bell
    Last Post: 09-26-2010, 09:51 AM
  5. The Bell of my shop
    By Bart Leetch in forum Old Iron
    Last Post: 07-29-2007, 03:34 AM
