Results 1 to 5 of 5
Thread: Pine - rustic finish
    Sep 2010
    Southern, Illinois
    106
    Hey all,
    I've got a pine mantel I've built for a fireplace and would like to preserve the rustic colors of the wood (blue staining & other discolors) and not end up with a glossy finish on it. Can someone suggest a finish I should use? I am going to guess some type of clear, but what kind? Poly is fine, but in my opinion that usually leaves a gloss finish. If at all possible, I prefer a wipe on type of finish as I am pretty new to finishes. Maybe I am asking for to much? Suggestions?
    Doug
    Apr 2009
    Outside the beltway
    5,255
    I would suggest a wax finish.
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    Thomasville, GA
    5,995
    Quote Originally Posted by Doug DeVore View Post
    ... Poly is fine, but in my opinion that usually leaves a gloss finish. If at all possible, I prefer a wipe on type of finish as I am pretty new to finishes. Maybe I am asking for to much? Suggestions? ...
    Doug,
    If you want to use polyurethane for the protection it offers, you can apply clear gloss, let it cure, then rub it out with pumice and/or rottenstone to achieve the desired sheen.
    Generally, I spray clear gloss lacquer. Then I rub it out with "FF" pumice to smooth it, which gives it a satin sheen. If I want more of a semi-gloss, I go back over it with rottenstone. It's easier than it may sound!
    Bill Arnold
    17,472
    for what your asking, i think you could put on wipe on poly and use a satin sheen of it..then rub as bill suggests,, at least 3 coats before rubbing it out and after its dry.
    Thomasville, GA
    5,995
    That's one way to get a satin sheen, for sure. I prefer to build layers of finish with clear gloss for visual depth. Then, by rubbing out the top coat you get the sheen you want and still maintain the visual depth beneath it.
    Different strokes!
    Bill Arnold
  1. Rustic Bench
    By Jay Caughron in forum Flatwork Project Showcase
    Last Post: 06-19-2013, 01:43 AM
  2. Rustic Tables
    By Mike Wagner in forum General Woodworking Q&A
    Last Post: 02-10-2011, 09:53 PM
  3. 'Rustic' Cherry
    By Ned Bulken in forum Hot Deals
    Last Post: 02-18-2009, 02:25 AM
  4. matching salvaged pine flooring to existing pumpkin pine floor
    By Robert Gilmore in forum Finishing School
    Last Post: 02-23-2008, 09:45 AM
  5. Suggestions for Cherry finish on Pine?
    By Dennis Thompson in forum Finishing School
    Last Post: 12-05-2007, 02:53 AM
