Results 1 to 10 of 13
Thread: Project: How to stack cut on the Scroll Saw
    5,533
    How to Stack cut on the Scroll Saw
    Hi gang,
    I'm actually Home tonight, so I thought I would do a little scrolling. Since there were so many nice comments on the 12 days of christmas project last week, I thought I would share my process of scrolling... and since I do have the nice camera, I documented it step by step. I dragged the images through photoshop and resized them so they shouldn't be too large for the average user. ENjoy!
    Continued...
    -Ned
    5,533
    I scroll to relax, and it can be nearly as 'immediate' as turning for a finished project, depending on the complexity. I picked a simple pattern for this project: in this case, the pumpkin in the middle of this image.
    I cut two strips of 1/8" ply to width, then sized them to the pattern:
    Once I have the stack the proper size, I tape the 4 edges together with masking tape, and tape the top face as well. The pattern then gets a quick dose of spray cement:
    no affiliation, but this little can is readily available at your local craft shop:
    After a minute to let it get tacky, I apply it to the stack, and then cover the top with clear packing tape, which helps lubricate the blade (lengthens the blade life) and keeps the pattern from lifting off in case the low tack glue gives up.
    continued...
    -Ned
    5,533
    Once I have the stack prepped, I turn to the drill press, and make pilot holes for all of the interior cuts, and usually one near the exterior, which makes the final exterior cut easier.
    here it is, ready to cut,
    Some basic scroll saw how to: generally you should cut from the center outward, as the piece gets weaker structurally the more material you remove. This piece was only 2x3" so I wasn't too worried about that.
    Here's the first two sections cut out: note that on skinny cuts which end in a point, I usually cut toward the point.
    rear of the same section:
    Again, I cut toward the point wherever possible, and I try to start at an 'outside' corner:
    Sometimes you don't have a 'good' start point, such as the eyes of the pumpkin in this piece. At that point, I start the pilot in the center, cut to the line, make a 90 degree turn and cut counter clockwise. (Most blades are stamped, and their teeth are set so that a counter clockwise cut is smoother than clockwise).
    look closely at the 'right' eye, I drew some arrows showing how I cut out the left eye.
    Experienced scroll sawyers can make very sharp turns, so from the entry point, I cut to the line, and all the way around to the right corner of the eye. At that point, I stop the saw, and re thread from the pilot hole. Cutting clockwise into the corner, this can give a crisper corner than the reversal technique. In this cut I think the results were about even.
    When it came to the mouth, I did things a little different. I wanted crisp teeth and corners, so I cut towards the corners of the mouth:
    here's how that looked on the back:
    there is only one pilot, the other 'hole' is where I looped the workpiece to make the tooth crisp and clean. That works, but only where you have lots of scrap 'room' to maneuver.
    I tried a different technique on the other corner. After I made the cut on the top section, I widened the cut a bit at the corner:
    This allowed me to reverse the blade into the corner, and then make one long smooth cut all along the bottom curve of the mouth:
    This shot also shows how I hold a piece, keeping my fingers out of the path of the blade in case the piece jumps.
    continued...
    -Ned
    5,533
    I slipped just a bit, and cut through the outer edge of the stack when I cut the exterior out... amazingly without going through the tape holding the stack together.
    Once I had the stack cut out, I peeled back the pattern, and then the masking tape from the face of the top piece:
    here is the back of the bottom piece: this shows typical tear out on the back of the stack. which is easily dealt with with a piece of 240 grit sandpaper:
    -Ned
    5,533
    I also cut out this pattern:
    along with a few miniatures:
    I also decorated the 'shop' a bit:
    Thanks for looking, hope you got something out of the process!
    -Ned
    30,015
    Great write-up, Ned.
    OK, I've gotta know...where'd you get the sign?
    5,533
    iirc Leo Voisine made that for me...
    -Ned
    10,604
    You got me thinking about dusting off my scroll saw. Nice write up Ned
    North West Indiana
    6,098
    Very nice write up Ned. That takes time to do it like you did documenting it. Thank you. What blade/blades are you using for this? When stack cutting or cutting the "critters" that are obviously thicker, what speeds are you using for each??
    Oh, love the sign!!
    Jon
    Thomasville, GA
    5,992
    Great tutorial, Ned!
    I've done a little scrolling - pieces to go on larger projects - always think about stuff like you showed but get busy on other things. LOML's co-workers have asked if I would make name plates for them like the one I did for her years ago. Any secrets to whipping out something like that?
    Bill Arnold
  1. Hey Rob, This would be a project for your Scroll Saw!
    Last Post: 03-07-2012, 03:08 PM
  2. Rockler has a 6" Dado Stack
    By Ned Bulken in forum Hot Deals
    Last Post: 04-15-2009, 07:43 PM
  3. Stack Dado Question?
    By Charles Hans in forum New Tools
    Last Post: 12-20-2008, 05:11 PM
  4. Wow results with my old dado stack . . .
    By Jerry Palmer in forum General Woodworking Q&A
    Last Post: 06-25-2008, 09:42 AM
  5. Freud 508 Dado Stack for about $135....
    By Mark Rios in forum Hot Deals
    Last Post: 02-20-2007, 08:58 PM
