Results 1 to 5 of 5
Thread: back cutting small radiused mouldings on the shaper
    here`s how i approach the task, down-n-dirty mdf throwaway jigs `cause the likelyhood of having to cut the same parts in the same fashion is next to nill and scrap is plentyfull.....
    ready for runnin` the "guard" is a holddown too, that`s why the screws are loose.
    guard removed, notice the copious amount of "woodlube"....(wax)
    shot of the "straights" and the radiuses after the first pass
    ready to sand and hopefully cut correctly the first time
    tod
    Last edited by tod evans; 11-10-2006 at 11:41 AM. Reason: spellin` or lack thereof
    15,774
    VERY cool Tod, nice to see how it is done.
    I'd love to have MDF here to play with, but it is just about as expensive as hardwood here....
    Southern Louisiana
    947
    nice setup and use of offcuts tod
    as always very helpful and informative.
    may i ask how you go about cutting those to fit the door (or whatever)
    thanks again for sharing your expertise
    chris
    chris, i cut the miters by marking the long-n-short points on a fullscale drawing then freehand on the mitersaw...tod
    Southern Louisiana
    947
    thanks tod
    you make it sound so easy. i'd be so nervous making those cuts!!
    chris
  1. Some big and small cutting boards
    By Jeff Bower in forum Flatwork Project Showcase
    Last Post: 10-01-2014, 01:06 PM
  2. Cutting small parts without cutting me..........
    By Ken Fitzgerald in forum Jigs and Fixtures
    Last Post: 01-28-2013, 03:30 AM
  3. small cutting board
    By Ned Bulken in forum Flatwork Project Showcase
    Last Post: 06-17-2009, 06:48 PM
  4. Pattern cutting on the shaper?
    Last Post: 01-31-2009, 04:25 PM
  5. Cutting very small pieces on TS
    Last Post: 02-04-2008, 01:26 PM
