Results 1 to 9 of 9
Thread: Strange Plane Modification
    Central NY State
    3,374
    This is a user's plane modification, that I've not seen before. The plane is a Union No. 7, same size as a Stanley 7. It belonged to my friend's grandfather or great-grandfather, and now belongs to my friend.
    3 holes, ahead of the iron, with a little dam in front of them. My guess is that it was for linseed oil, or some other lubricant.
    Anybody ever see or hear of this before?
    5,321
    That IS strange.
    Your guess of an 'oil pool' is probably right, but it'd sure make finishing a mess - unless you're just rubbing on some more oil.
    You gonna try it out to see if/how well it works?
    Someone had a "Good idea" that did not catch on?
    Or could it be that wood was not the material being cut? Could the plane have been used to cut something else, like say leather, and the lube was needed?
    May 2008
    Bellevue, WA
    38
    I'm going to guess this was an experiment that didn't work out. I'm thinking it was to lubricate the sole of the plane, similar to rubbing wax or camellia oil on the sole.
    However, I don't think the 3 holes would have spread the lube wide enough, nor controlled the flow rate well, and maybe more importantly, the planning action would have planned off the lube before it got to the back of the plane.
    But what do I know.
    Maybe it was not for oil at all, maybe it was for a thinner of some kinds. Could be that they had a very resinous wood that was gumming up the sole and the blade, so they put some kind of thinner, or maybe even something as simple as kerosene to help keep the resin from building up on the plane
    I guess we will never know
    12,256
    Whats the chances that it was not at all for wood use and that the fluid move up through the holes from the workpiece. Like say harvesting something from some surface.
    Ken send a pm to Rob Lee of l.v. he is a member here. He is also a member of an old tool organisation in Canada i forget where they meet at the moment. He may be able to shed more light.
    30,017
    They're air vents for cooling the blade.
    Glad I could help.
    Los Angeles, CA
    2,668
    Glad I could help.
    Best explanation so far. This guy is a genius.
    Central NY State
    3,374
    Thanks to Rob Keeble for his suggestion, and to Robin Lee for his answer. Looks like lubrication is the likely explanation.
    http://www.google.com/patents?id=rMt...page&q&f=false
  1. Strange
    By Paul Douglass in forum Off Topic Discussion
    Last Post: 06-23-2014, 01:41 PM
  2. A successful modification.
    By John Pollman in forum Off Topic Discussion
    Last Post: 03-24-2011, 11:30 PM
  3. DW735 modification
    By Drew Watson in forum Old Iron
    Last Post: 10-21-2010, 12:07 AM
  4. Caliper modification
    Last Post: 02-25-2008, 05:38 PM
  5. Very Strange
    By Bruce Page in forum General Woodworking Q&A
    Last Post: 11-16-2007, 11:41 PM
