Results 1 to 10 of 10
Thread: Shop Made - Fairing Stick
    9,077
    You've seen these fairing sticks (used for drawing arches) before and they are super simple to make. I have a small one but, found a larger one would come in handy for my current project. Rip a strip of hardboard on the tablesaw so it is dead-accurate. Drill a pair of holes about 1/2" apart near each end. Cut a smaller piece to act as your locking slider and drill a hole near each end on it.
Name:	Fairing Stick 1.jpg
    Tie a piece of line to one end, feed it through the slider, feed it through the holes at the other end of the stick and run it back to the slider. Tie the line off at the slider.
Name:	Fairing Stick 2.jpg
ID:	61234 Click image for larger version.
Name:	Fairing Stick 3.jpg
ID:	61235 Click image for larger version.
Name:	Fairing Stick 4.jpg
ID:	61236 Click image for larger version.
Name:	Fairing Stick 5.jpg
    And there you go. Here's a pic of the small one so that you can see the whole thing better.
Name:	Fairing Stick 7.jpg
    Bow the stick and take the slack up with the locking slider. Once the initial stretch is out of the cord it will retain its form for extended times when you wnt to repeat a curve layout on several pieces. The 1/4" hardboard has enough of an edge to allow clamping in place before you draw your line. Release the tension and they store almost anywhere without taking up much room.
Name:	Fairing Stick 8.jpg
ID:	61240 Click image for larger version.
Name:	Fairing Stick 9.jpg
ID:	61241 Click image for larger version.
Name:	Fairing Stick 10.jpg
    Dec 2008
    Santa Claus, In
    4,779
    Looks like it should work. Now lets see you make a tapered one to do oblique curves
    9,077
    Quote Originally Posted by Steve Southwood View Post
    Oddly enough, I have made these that are 2" wide at one end an 8" wide at the other. When bent they form an asymmetrical arc. They are sort of a one-trick-pony and I needed the room so, they went in the scrap bin. This one was to allow me to layout these repeating curves. They lead me to this lift shape which should allow me to make this component.
    Attached Thumbnails Attached Thumbnails Fairing Stick 011.jpg   Fairing Stick 12.jpg   CoD-1-2011-10-16-cloudlift-.jpg
    Dec 2008
    Santa Claus, In
    4,779
    Scrap bin, you need a bigger work area.
    Jun 2007
    4,944
    Glenn,
    How do you "tie-off?" If you just tie around the string, it will slip. Did you use a fancy knot that only sailors and Boy Scouts know?
    If there were a couple machine screws sticking up 1/4 inch, you could "Figure 8" loop around them. Or perhaps one of those miniature cleats they wrap venitian blind cords around...Then you would not need to tie.
    Mom called "Snack Time." So G'bye.
    Enjoy,
    JimB
    VOTING MEMBER
    Southeast Pa
    2,019
    That isn't fair, to easy!
    9,077
    Quote Originally Posted by Jim C Bradley View Post
    Glenn,
    The friction on the line passing through the slider creates a lock, Bow the stick, slide the slider up to take out the slack and it says.
    Jun 2007
    4,944
    Glenn, that's too easy and logical. I just knew that there had to be a more difficult way.
    Enjoy,
    Dad
    VOTING MEMBER
    Central NY State
    3,374
    Nice piece of equipt. I like the price too.
    SE Minnesota
    2,526
    Cool jig, Glenn.
    When I was building the sailboat I needed a very long flexible batten to spring for the curves. I didn't have anything on hand that would work but I found something that worked perfectly in the local DIY store. I was able to buy a very long piece of pine screen door stop. That's the trim stuff you nail down over the edges of the screen on an old fashioned wooden screen door. Unlike a lot of the trim available, this stuff is made from a single piece of wood. It was fairly cheap and ready to use.
  1. Shop Made Pulls
    By glenn bradley in forum Flatwork Project Showcase
    Last Post: 11-16-2012, 05:21 AM
  2. Shop Made Pen Press
    Last Post: 08-03-2012, 03:02 AM
  3. Shop made scaffolding
    By Joe Scharbrough in forum Carpentry and Construction
    Last Post: 01-14-2010, 03:26 AM
  4. Shop-made box latches- where did I see them?
    By Charlie Schultz in forum General Woodworking Q&A
    Last Post: 10-16-2007, 03:53 PM
  5. Shop made Spokeshaves
    By Mike Henderson in forum Handtool Project Showcase
    Last Post: 02-05-2007, 09:42 PM
