Results 1 to 10 of 13
Thread: Rattlecan: Poly vs lacquer
    Constantine, MI
    7,892
    Question Rattlecan: Poly vs lacquer
    I have several small boxes to make. I'll be using walnut, QSWO, and mahogany. I have used spray can poly before with acceptable results, but there is a long wait for re-coating and the dry time allows dust to settle in the finish. These are display boxes and won't see regular handling, so the scratch resistance of the poly is really not an issue.
    I've been thinking about using spray can lacquer as my finish. I'd start off with a coat of thinned dewaxed shellac to bring up the grain and color, light sanding with 320, then apply as many coats of finish as needed, sanding/steel wool between coats as needed.
    If I understand what I have read to date, the lacquer has a faster dry time and can re-coat sooner. With poly I can do 3 coats a day with no problem if the conditions are good. However, that means two days to finish.
    Can I cut down the finish time using lacquer?
    www.wrworkshop.com
    Dec 2008
    Santa Claus, In
    4,779
    Sorry I can't help with the Lacquer. What about a wipe on poly? You can mix in some Naptha and it will dry fast. Also hearing that the newer water base wipe on, dry really fast.
    Rule of thumb is if you don’t know what tool to buy next, then you probably don’t need it yet.
    I use quite a bit of rattlecan lacquer on turned pieces, and I like it a lot. It is ready to re-coat much sooner than poly, and like you said, there is less chance of the wet finish getting contaminated with dust. And although I do use a wipe-on finish quite a bit too, I like spraying because it's easier to keep from getting handling marks in the wet finish as I'm applying it.
    I get my best results when I apply lighter coats than I think I need.
    Depending on conditions you can sand and re coat in as little as 30 minutes using lacquer. I love the stuff for ease of use!
    Villa Park, CA
    1,407
    Quote Originally Posted by Steve Southwood View Post
    The only problem with the water based wipe-on is that it raises the grain. I tried it but went back to the oil based.
    Lacquer dries pretty quickly. I use a water based spray lacquer but put dewaxed shellac on first to avoid the grain raising problem. I use a spray gun - I don't think water based lacquer is available in a rattle can.
    Mike
    Ancora imparo
    Constantine, MI
    7,892
    Good advice from all - thanks/ I think I'll give it a try soon. Any brand that you like over the others?
    www.wrworkshop.com
    Dec 2008
    Santa Claus, In
    4,779
    I have only tried it once Mike. I used a spray bottle and raised the grain first. Worked pretty good. It does add time to a project, to pre-raise the grain.
    Oliver Springs, TN
    1,726
    I like deft that I get at Lowes. I can get 3 coats in a couple of hours with good conditions.
    Central NY State
    3,374
    Rennie, have you tried wiping on shellac, at a 2# cut? A thin coat will dry in an hour or so.
    Constantine, MI
    7,892
    Quote Originally Posted by ken werner View Post
    I wipe on shellac as a first coat on most all my projects. I usually follow with several coats of wipe on poly. However, for these small boxes I was thinking it would be much faster to apply the one coat of shellac, sand, assemble and then finish with spray. Wiping on a finish on a small item with lots of nooks, crannies, and inside corners can get to be a real pain.
    www.wrworkshop.com
  1. outdoor poly or lacquer water based for spraying
    By allen levine in forum Finishing School
    Last Post: 04-08-2016, 02:26 AM
  2. Lacquer EM6000 and Poly 9000 - Discount this month from Target Coatings
    Last Post: 03-12-2012, 03:05 AM
  3. Spraying Lacquer or Poly
    Last Post: 03-02-2012, 02:40 AM
  4. Poly Problem
    By Brian Gallagher in forum Finishing School
    Last Post: 07-29-2009, 04:26 PM
  5. What to thin poly with???????
    By Al killian in forum Finishing School
    Last Post: 12-07-2007, 04:51 PM
