Results 1 to 9 of 9
Thread: Fixing a Chipped Lever Cap?
    30,017
    Can this old Stanley lever cap be salvaged by grinding down the chipped edge?
    Central NY State
    3,374
    Yes, but it won't look quite right.
    Worth a try, otherwise it is just scrap
    Southeast Pa
    2,019
    Build it up with weld and then grind it back to shape...
    5,322
    You could actually use it, just like it is, but building it up with weld, and grinding it back to its original length would be better.
    As long as it holds the blade in place, that's all you really need, though.
    I have one just about like that. I just use it.
    30,017
    Quote Originally Posted by ken werner View Post
    Looks won't make much difference to me as long as it still functions correctly.
    Quote Originally Posted by Garry Foster View Post
    Hadn't thought of that. I'd have to get a local shop to do it, since I don't have a welder (and would likely mess it up if I did).
    Thanks for the info and suggestions, gents.
    13,361
    Was it just rust that ate away the edge? Just curious.
    Central NY State
    3,374
    Some old-timers used the lever cap as a screwdriver for the chip breaker. That is usually the cause of lever caps that look like that.
  1. need a lever cap..// it came with a friend:)
    By larry merlau in forum Neander Tool Questions and Show & Tell
    Last Post: 01-09-2014, 05:35 PM
  2. New stanley 9 1/2 (chipped)
    By Dan Thibert in forum General Woodworking Q&A
    Last Post: 06-03-2009, 02:19 AM
  3. How I solved my chipped veneer problem
    Last Post: 02-02-2009, 05:32 PM
  4. How do you adjust a plane's lever cap
    By Richard Line in forum Neander Tool Questions and Show & Tell
    Last Post: 05-16-2008, 04:18 PM
