Results 1 to 9 of 9
Thread: Bowling along again.
    Cotswolds, UK
    629
    Just a little change in form, just to be different.
    Beech and Walnut 220mm diameter (8.66")
    Attached Thumbnails Attached Thumbnails DSCN3014 (Medium).JPG   DSCN3015 (Medium).JPG
    Chas. just a traveller on the road of time.
    Bits & Pieces Gallery
    My Web Site
    Independence, Kentucky
    1,355
    Chas looks great as always I like the shape variation that you did on this one.
    Chuck
    North West Indiana
    6,099
    Chas, I would love for you to teach my turning class for a week or more. I'd be right in the student section learning along with the rest!
    Jon
    Goodland, Kansas
    4,834
    Chas great looking bowl. Really well done.
    Bernie W.
    Aug 2011
    Hitchins, Kentucky (Northeastern part of the state.)
    80
    Great work! I really like the contrast on your segmented bowls. When you glue up the blanks, do you use wood that has already dried, or do you use green wood?
    Cotswolds, UK
    629
    Quote Originally Posted by Raymond Scott View Post
    ..... When you glue up the blanks, do you use wood that has already dried, or do you use green wood?
    Raymond, The wood is dry, all the recent pieces are made up from off-cuts from a furniture manufacture and are below 8% moisture.
    Green wood, or even wood with more than about 10% moisture is likely to fail along the narrow glue lines due to wood shrinkage.
    In fact wood that I have home dried I will not risk using until it's down below 6% which is almost the lowest reading on my meter.
    If I have any doubts I leave the rough turned rings for a couple of weeks to allow glue moisture etc. to dry out.
    Just checked these I turned about an hour ago and they are all below 4% moisture.
    My Web Site
    Nicely done (as usual) Chas.
    Sent from my iPhone using Tapatalk
    Cotswolds, UK
    629
    Quote Originally Posted by Jonathan Shively View Post
    Jonathan, you would probably be shocked at my methods and approach to turning, the only thing that registers with me is the finished item, how it's constructed and tools used are all done on what might be termed 'lowest common denominator' basis in both work involved and costs.
    DIY level 14" Bandsaw, but fitted with the best blade I can buy and tweaked to cut true.
    Low budget chop saw, but fitted with good blade and adjusted for as near perfect angle and squareness to table that I can achieve.
    Lathe tools, use as few as possible and as basic in form as possible from a good manufacturer, but no exotics.
    Only work on wood during preparation if it actually needs it for next process.
    Same with finishing, as these are buffing wheel finished, just sanded to 240grit no point in going further.
    Look at the clamped bits in post above for next little boxes.
    The Oak top and bottom is as cut out from previous larger box tops, just dressed each side for mounting socket and foot and mating surface for ring. The walnut ones rough cut on bandsaw from scrap and likewise socketed and mating surface prepared.
    The rough clean up of those rings and the two pairs of top/bottoms took about 45mins including changing chucks between Cole Jaws and Dovetail.
    (work saving tip here, Cole jaws are fitted on a 5" chuck so they give much wider range without moving buttons)
    Note there's no attempt to make the components or work surfaces not needed for accurate fitting look pretty, just trued up enough to provide alignment guides.
    My Web Site
    Jun 2007
    4,944
    Chas,
    It is an old saying, however it is really true, "You do beautiful work." Anyone who owns one of your works of art should be so pleased that the light from their face illuminates the entire house.
    Enjoy,
    JimB
    VOTING MEMBER
  1. Bowling anyone.
    Last Post: 03-19-2015, 03:41 AM
  2. Bowling in rental shoes
    By Ken Cook in forum Lathe Project Showcase
    Last Post: 12-20-2011, 07:47 PM
  3. Student's bowling pins and ball
    By Jonathan Shively in forum Lathe Project Showcase
    Last Post: 05-20-2011, 09:50 PM
  4. Bowling Pin Woodworker's Mallet
    By Frank Townend in forum Lathe Project Showcase
    Last Post: 01-19-2009, 04:45 PM
  5. Bowling Pins?????
    By Matt Dunlap in forum General Woodworking Q&A
    Last Post: 03-04-2007, 08:07 PM
