Results 1 to 2 of 2
Thread: Stationary Sanders
    Jun 2010
    3,220
    Stationary Sanders
    Can someone educate me about the sanders that sit on your bench. I know some are disc, some are belt and then there's spindle. I know there are some contraptions that combine 2 or more of these in one machine.
    I've been sanding by hand. And I also have an old B&D heavy as lead thing that vibrates. And I have an ROS too. While using the heavy thing the other day, I discovered that if I just rested it on its side on the bench, I could hold the workpiece up to it with less effort than moving the heavy thing around. So a light bulb went on, and I thought, this is what belt sanders are for. (I think).
    So is it worth it to get a combo machine? Is a spindle better than a disc? Are the belt sandpapers easy to come by in different grits?
    Thanks all.
    AKA The Rookie
    Dec 2008
    Santa Claus, In
    4,779
    http://familywoodworking.org/forums/...ad.php?t=25393
    Was a good discussion on this couple weeks ago. You should find what you are after here, I think.
  1. combination sanders
    Last Post: 11-05-2012, 02:23 AM
  2. Drum Sanders
    By Bill Casassa in forum Site Questions and Test Posts
    Last Post: 02-11-2011, 12:12 AM
  3. shop built wood storage rack, stationary.
    By Jim O'Dell in forum Carpentry and Construction
    Last Post: 12-06-2010, 04:27 PM
  4. Sanders
    By Paul B Cresti in forum New Tools
    Last Post: 02-24-2007, 05:39 PM
  5. Need Stationary Compressor Advice
    By Jerry White in forum New Tools
    Last Post: 12-11-2006, 12:04 AM
