Results 1 to 10 of 19
Thread: Turning woodworking dust and chips into burnable "logs"
    Toronto, Ontario, CANADA
    2,332
    This week, I successfully burned a pressed log that I made solely out of dust and chips collected in the woodworking shed. For a long time, I have been crerating more dust and chips than I can easily dispose of. The city doesn’t want them either in garbage or in garden recycling material. I tried then as mulch, but the material tends to clump up and, so, later it becomes hard to work into the soil. It is possible to incorporate a bit of the dust and chips into my own compost bin where it is well mixed with other material. It is also possible to burn by throwing handfuls onto a fire in the stove my workshed, but that is messy. As a result of all this, I have now accumulated 5 very large paper bags of dust and chips. Here is a photo of two of the bags:
Name:	Bags of woodworking dust and chips -small.JPG
    What to do? The clumping in the garden gave me an idea. I drilled some holes in a large can, made a removable wooden top, wet some dust and chips, pressed them into the can, then let the mixture dry for a couple of days. I thought that the clump would simply drop out of the inverted can, but that didn’t work. I had to take off the bottom and cut the can down the side in order to remove the log”.
Name:	Compressing woodworking dust and chips in can -1 -small.JPG
ID:	61452 Click image for larger version.
Name:	Compressing woodworking dust and chips in can -2 -small.JPG
    After drying the log for another five days, I put some kindling under it in the stove, lit the kindling, and obtained a good fire. Here is one photo taken about five minutes after lighting the fire and another taken twenty minutes later:
Name:	Burning compressed log -1 -small.JPG
ID:	61454 Click image for larger version.
Name:	Burning compressed log -2 -small.JPG
    By the way, the dried log held together fairly well before I burned it, but it certainly would have come apart if not handled gently.
    Cheers, Frank
    2,332
    Of course, I don’t want to cut a can apart for every log that I create so, this week, I built a form that can be used to make a large rectangular “log” block:
Name:	Pressed block of woodworking dust and chips -1 -small.JPG
    The form is designed to be temporarily held together with clamps. In the first picture below, the dust-chip-water mixture is being pressed into the form and in the second picture the lid has been hammered down pushing out as much water as possible:
Name:	Pressed block of woodworking dust and chips -2 -small.JPG
ID:	61457 Click image for larger version.
Name:	Pressed block of woodworking dust and chips -3 -small.JPG
    After a couple of days, the form was removed:
Name:	Pressed block of woodworking dust and chips -4 -small.JPG
ID:	61459 Click image for larger version.
Name:	Pressed block of woodworking dust and chips -5 -small.JPG
    There is a small crack about two thirds of the way from the left side of the block, but I don’t expect this to be a problem.
    The next time I make a block, I will mix in a little plaster of Paris, and see if that improves the solidity
    Cheers, Frank
    15,809
    Frank, how about a 6" piece of HD PVC pipe? Cap on one end, NOT the PVC ones as they are hard to remove, but a wooden one and then a small hydraulic jack? Got to be careful, as you would be making a lot of pressure.
    I think you should just buy your milk in the old style paper cartons, then pack the sawdust into the carton, they would lite easy too!
    2,332
    Stuart, I like your second suggestion and will give it a try. The olny problem I see is that milk is more expensive in those containers.
    Cheers, Frank
    new york city burbs
    10,188
    Ive noticed on several occasions when I put out bags full of only sawdust, my trash collectors, one of them put the bags into the cab of the truck.
    I figured he must be using it for either his garden or some slippery and wet work area.
    I never asked him. Im happy they just haul it away and thats that.
    Human Test Dummy
    Sounds like a great idea,
    I was just thinking that a piece of PVC pipe would do a great job as the brick probably hangs up on the ridges of the can.
    Once again, back when I could do it, I used to take the dust and shavings out to my daughters property and scatter into the woods undergrowth. Also in the fall we would pack lifted flower bulbs in damp sawdust tucked safely in a dark corner of the basement. Also a neighbor of my daughters used to take it to scatter about in the mud around his barn and feedlot.
    The the dust/shavings log is a good idea if you can figure a quick and easy method of compressing. I believe those fire starters are simply wax and compressed dust. Keep trying to find a way to recycle dust and shavings as we all have a common problem.
    Jun 2010
    3,220
    That's a terrific idea.
    AKA The Rookie
    2,332
    I have been asked about the amount of water that I used in the mixture.
    The rectangular block is approximately 10cm x 10cm x 40cm and I used about 2 litres of water.
    Cheers, Frank
    Austin, Texas
    1,448
    Although I haven't tried it, I have dreamed about the PVC pipe bit, and the shavings mixed with a small amount of flour. In old days, ordinary baking flour and water was used for paste (even as wallpaper paste), and when dry, flour burns. Therefore my untested plan included using flour in the water to make a better binder for the shavings in the log.
    Charlie Plesums, Austin Texas
    3,135
    Well well well how about a chunk of well casing or steel pipe, with weep holes all around with a lid held in place much like a paint pot. Welded into a frame work with a chunk of round plate to come up from the bottom & a hydrolic jack to press the water out.
  1. Interesting info on the "Dust Deputy"
    By Bob Gibson in forum Off Topic Discussion
    Last Post: 04-20-2015, 11:47 PM
  2. Problem turning "Willow" bowl blank UPDATED with PICS
    By Tom Baugues in forum General Woodturning Q&A
    Last Post: 08-23-2014, 08:06 AM
  3. I've seen dust bunnies, but "lint orbs"?
    By John Pollman in forum Off Topic Discussion
    Last Post: 03-09-2013, 05:14 PM
  4. "Tornadoes" from my dust collector!
    By Gary McFarlane in forum Shop Tours
    Last Post: 09-19-2009, 04:30 PM
  5. "Dust Collector Remote"???
    By Lary Grassmeier in forum General Woodworking Q&A
    Last Post: 07-23-2007, 08:42 PM
