Results 1 to 10 of 14
Thread: Negative Rake Scraper
    Goodland, Kansas
    4,834
    I have seen a lot of talk on other forums about negative rake scrapers and I have been thinking about it for a while. So I went to PSI and bought a 3/4" sqaure end scraper. I took and ground it to a combined angle of 42*. It looks like a skew. I had been in contact with Cindy Drozda who has been great in helping. Anyway once I got the shape I wanted and is one she suggested then you only sharpen on one side so you have a burr on the top side. I will say this. I have been working on another lidded box like the finial star. I used it on the inside of the lid and the top side of the lid. I can say it does a great job with thin, wispy ribbons and I actually finish sanded it with just 400 and 600 grit. Anyway the finish on the inside and outside was just smooth like glass. I also wanted it to try and lighten the dye like she does on the background colors. So will continue to try it on different projects to see how it goes.
    Attached Thumbnails Attached Thumbnails Negative Rake Scraper 1.jpg   Negative Rake Scraper 2.jpg
    Bernie W.
    Yorktown, Virginia
    5,022
    Bernie, I really like mine, but those burrs only last for a blink.
    Oct 2009
    Near Gassaway,West Virginia
    105
    Bernie that is rather unusual grind. I may have to give that a try. I use a negative grind on some of my scrapers but I just use a diamond file and put a 10 or 15°bevel on the top and a regular scraper grind on bottom. I like how mine works, but may give your way a trial. Thanks for posting.
    Goodland, Kansas
    4,834
    You are right Ted. They don't last long for sure but boy do they work nice. Fred I used this tonight to work on a chinaberry bowl that was giving me fits. It is kinda like elm. I just couldn't get it smooth with a gouge or shear scraping. So I mounted it up and in 3 passes it was done. I started sanding 220 and 320. Put my first coat of finish on and the inside now is smooth as glass. I am happy with the tool. I know it is not a cure all but it does have it's place in a turning arsenal.
    Bernie W.
    That is great!
    I really think it is all about having the right tool for the job, I know this means that sometimes you end up with a lot of tools, but I'd rather have a special tool to solve the problem then spend the farm on using more and more sandpaper!
    Goodland, Kansas
    4,834
    Amen Stu.
    Bernie W.
    Grand Rapids, MI
    383
    Very nice tool! Another thing worth noting is that if it's honed to a mirror edge you don't necessarily need a burr, especially on really dense woods (like exotics). I used a radius-edged skew honed to a "carving tool" edge as a negative rake scraper on a recent project. It worked superbly even without a burr.
    Hutch
    Jul 2007
    DSM, IA
    5,719
    Bernie thanks for the pics on how your shaped the scraper...Hutch thanks for telling me what to do with my skew that I've never even used!
    My Website
    Goodland, Kansas
    4,834
    Your welcome Jeff. Hutch I did use a skew for a long time but I just got tired of honing and sharpening my expensive Lacer skew. I think Ken Fitzgerald and I are about the only one's that love skews.
    Bernie W.
    Feb 2011
    Ladner BC
    42
    Hey Bernie and all the rest of you really bright guys.
    I understand that this 'negative rake scraper' seems to work really well but I have a lot of difficulty understanding the physics or engineering principalof it.
    In my very small mind it would seem to me that all one does with a scraper is place the cutting edge against a spinning thingy. Again, logically at least to me, the only angle that I can understand is the angle that the edge is place against the spinning thingy.
    So can any of you let me in on the logic that would explain the difference between a regular scraper and a scraper that is sharpened on both sides?
    When I first saw Cindy using a scraper sharpened like this I said to myself, "self me things someone is pulling your leg and trying to get you to buy another toy for your lathe but now with all of you touting the benefits of this tool . . . .
    This is probably a lot like golf. I play, or try to play a little and now I hear that if I want the ball to 'draw' (that is go a little left) I should aim right.
    Likely the same logic, that my muddled brain can't comprehend.
    Pete
  1. Negative rake scrapers?
    By Roger Tulk in forum Turning Tool Questions and Show & Tell
    Last Post: 08-02-2015, 11:15 AM
  2. Difference Between a Bowl Scraper and a Shear Scraper
    Last Post: 06-19-2012, 05:02 AM
  3. Negative Rake Scraper
    By Bernie Weishapl in forum Turning Tool Questions and Show & Tell
    Last Post: 01-09-2009, 02:00 AM
  4. about negative rake blades
    Last Post: 06-25-2007, 12:43 PM
