Results 1 to 10 of 11
Thread: Tipping DrillPress?
    London, Ontario
    3,383
    Tipping DrillPress?
    Soooo, over in Cynthia's shop tour thread she noted that her Drillpress was chained to the wall, so it wouldn't tip over.
    I've never chained up my Drillpress (DP). I've "walked" it out from the wall/corner many times when I needed to -- you tip it over a bit onto one side of the base and then angle forward and tip back to the other side, repeat until done.
    I've never had it tip either.
    So I'm really curious. How many of you have tipped your DP? More than once?
    I don't think I've ever seen a chained DP before.
    Last edited by Art Mulder; 11-10-2011 at 11:49 AM. Reason: (Edited to clean out the excessive amt of DP acronyms...)
    Thomasville, GA
    5,992
    Tipped one time with something heavy. Caught it, then anchored it to the concrete floor! (I'm only half blonde!)
    Bill Arnold
    Jun 2010
    3,220
    I tipped mine and couldn't catch it like Bill. Kaboom! Not again.
    AKA The Rookie
    May 2009
    Syracuse, Nebraska
    669
    Bolted mine to a wider plywood base with the edges beveled so there's not a tripping problem. About a foot wider left, right and front, and can pull it away from the wall if needed.
    Oct 2009
    Dennison, MN
    512
    DP=drill press?
    Can we settle down with the abbreviations. Please?
    "Do, or do not. There is no try."
    -Yoda
    13,357
    Only time mine was ever tipped over was when it was delivered. I'm assuming the delivery guy left it leaning up against the wall in front of the door. When I got home it was laying flat on the ground with all the packing material 'exploded' around it...
    First piece of equipment I ever ordered quite a few years ago. It's still running strong...
    No damage...
    Mar 2010
    Decatur, Alabama
    518
    I've never tipped one over completely, but I've used a small floor drill press with a little base that I had to catch before. If you need it to be mobile and have a DP with a smaller base, bolting it to a piece of plywood 2'x2' would do wonders for it's stability. Also seen in a magazine somewhere a guy put a base like that on his dp and put UHMW pads on the corners so he could slide it around where he needed it.
    Jun 2007
    4,944
    I have walked my inherited Delta DP (from my father) around many times over the years to move it.
    The new Delta that I have (2-3 years old), I would not even dream of walking. That son of a gun is HEAVY and really top heavy. Tilt it one degree too much and kiss it goodbye...nothing would stop it. I made a larger base with wheels for it. I retract the wheels when not in use. I have only moved it a couple of times. The base works well. I did a thread on it shortly after purchasing.
    I am confident that it would ride out one of our Southern California earthquakes (No. Murphy you cannot play with this.). I had rolling earthquakes on my mind when I designed the base.
    Enjoy,
    JimB
    VOTING MEMBER
    London, Ontario
    3,383
    Quote Originally Posted by Karl Brogger View Post
    DP=drill press?
    Sorry Karl, it was totally unconscious. I've cleaned out most of them.
    Jul 2007
    DSM, IA
    5,719
    Mines not a floor model, but I've a nice scare on top of my head that reminds me they are top heavy and I can't catch it when it's falling down...
    My Website
  1. Interesting Drillpress table Idea
    By Dan Mooney in forum Jigs and Fixtures
    Last Post: 04-22-2011, 08:14 PM
  2. Replies: 15
    Last Post: 01-19-2011, 04:46 AM
  3. Delta 14-207 Drillpress
    By Jim C Bradley in forum Old Iron
    Last Post: 04-13-2008, 11:52 AM
  4. Delta drillpress mortiser
    By Rick Levine in forum Old Ads
    Last Post: 07-10-2007, 02:32 AM
