Results 1 to 7 of 7
Thread: Do I HAVE to paint over primer?
    May 2009
    Lafayette, Indiana
    2,380
    I need to paint the walls of my new shop. The walls are OSB plywood. I've decided to use an Oil based primer. After buying the primer I got to thinking....do I HAVE to paint over the primer? I want white walls. The primer is white. Is there any reason that I HAVE to apply paint over the primer? I'm thinking two or three coats of primer and I should be good.
    17,472
    on mine tom, i used the primer to seal the osb then gave it two coats of top coat which was semi gloss,, makes sweeping the cob webs off easier than a dull primer would..
    May 2009
    Lafayette, Indiana
    2,380
    that's what I'm wondering about. I want as smooth of a surface as possible so if I need to paint I will.
    17,472
    it still is gonna be rough to some extent,,OSB isnt made to be smooth but its easy to clean the semi gloss and is white,,
    North West Indiana
    6,098
    On metal yes because the primer is somewhat porous as this aids adhesion of the paint to the metal. Larry answered the rest as best I think it could be. I did the same with mine, primer and then two coats of gloss white. Makes it brighter and easier to sweep down.
    Jon
    2,784
    Well, I'm going to go the other way. I put 2 coats of Kilz II (latex) on my OSB walls and ceiling and left it that way. It has a slightly grey tint, but is basically white. I figured if I ever needed to paint, no problem. In 5 years I haven't found a need. Jim.
    Coolmeadow Setters...
    Exclusively Irish!
    May 2009
    Lafayette, Indiana
    2,380
    Quote Originally Posted by Jim O'Dell View Post
    Well, I'm going to go the other way. Jim.
    Oh thanks Jim...now I'm totally confused... No seriously....Actually I think this was just my "cheap" side kicking in and hoping to save $15.00 on paint. God knows I've spent evough on this project already. I'll put the primer on and see what it looks like then make a decision. I got the last wallboard put up tonight so painting will be next but my work schedule has me busy non-stop for the next two weeks so I'm not going to get anything done till then.
  1. primer over silicon sealent?
    Last Post: 09-17-2013, 12:30 AM
  2. Excellent Primer on Planing Square
    By Bill Satko in forum Neander Woodworking Q&A
    Last Post: 09-13-2012, 02:37 PM
  3. Paint help
    By Jeff Bower in forum Old Iron
    Last Post: 07-31-2007, 01:37 AM
  4. Paint help
    By Jeff Bower in forum General Woodturning Q&A
    Last Post: 07-30-2007, 08:50 PM
  5. Help Stu Paint his saw!
    By Art Mulder in forum Finishing School
    Last Post: 06-06-2007, 01:36 AM
