Robert Horky
My plan calls for an oak skeleton/structure with a walnut/curly maple veneer skin. The skeleton is planed to 3/4" and all pieces cut to length/width. The form for the front bent wood laminations is made and the laminations completed, 3 pcs of 1/4" each to make up the 3/4" thickness. Did get some spring back but can pull it out during assembly. I will reduce the thickness to 3/32" or 1/16" when doing the walnut skin. Have a few more half laps to cut , the bottom shelves to cut and the top to cut, then final dry fit and assemble the skeleton. More to come as I progress.
