Results 1 to 10 of 30
Thread: Road Case Hardware
    13,462
    Road Case Hardware
    I'm in the middle of my first upholstery project. Also in the middle of building some equipment that will be used in a current business venture (Wright venture 1002...in Fusco terms). This piece will host a lcd screen and mini computer along with a few other pieces of media equipment. It's my first time using speaker carpet to cover a case. I'd have caught some pics of the hands, but they were covered in 3M 77 spray, fuzzy black fibers and wasn't touching my phone; luckily they peeled clean nicely. The cabinet is made of 1/2" plywood with 3/4" MDF top and bottom.
ID:	62662Click image for larger version.
    Anyhow I found a great place for the road case hardware (speaker carpet, steel corners, latches, etc.), Reliable Hardware, nice folks to do business with. Here is how it turned out so far. I sprayed the 3M 77 on both the case and carpet, let them dry some to finish trimming out. Once the adhesive dried some, you could lay one piece of the carpet over the other and cut through both for a matching seam. Just peal back the top layer and put out the scrap from underneath. There's not really any grain in the carpet, so both sides of the seam butt together nicely without a noticeable seam.
ID:	62664Click image for larger version.
ID:	62665Click image for larger version.
    There's definitely a method to the madness, a little practice and this should be pretty easy if I need to do more of them, but it turned out pretty good overall.
    12,264
    Looking real good but i would add some bling in the form of leds around the edges somewhere. The kind the kids use in the cars today you get in a strip and are multi colored. You can hook em up to the processor and make em do things to catch attention.
    Make sure to mount display with some sort of vibration buffer given case size or you gonna have cracked lcds.
    13,462
    Thanks Rob. I've got some of the RGB strips on the list to order and had already figured out that I can run them off the pic controller that is being used for the other controls. I'm thinking that I'll probably use them on a detachable sign or hood to make it easy to add-on. I've got an idea for some portable screens that they could be used in as well. I can then alter the colors or set them to a color(s) that matches the customer's theme too.
    Good note on the lcd mount. I think I've got something that will work well, to protect it.
    13,363
    Looking good Darren! Very professional
    Central NY State
    3,374
    Looks like a fine custom build.
    13,462
    I got most of the hardware mounted in the photo booth tonight. Here's the first test and sneak preview.
    This was a test mock up of mounting the equipment. I'll be pulling it back apart to make some final adjustments to the case and fix some of the covering, but it's turning out pretty well (IMHO). I have one little fix to do. The power button for the monitor is on the front and I forgot to leave access to press the button...easy enough fix though. Still need some opaque white plastic and to mount the light and cooling fan too.
    Here's one of the guts and the mini computer.
    Jan 2011
    3,798
    That's just tooooo cool! & great job on the carpeting, I had an old 'York' Bass amp covered with something similar, held up great!
    Too cool, Darren. It looks very professionally done so far. What software are you using? Is it something you wrote or is it a commercially available product?
    13,462
    Thanks. It's a commercially available software, this one is called Spark Booth. It was the easier more user friendly version and easy to get up and running. It allows overlays of the prints to include custom graphics. Can also customized the main screen to match a clients event. The other affordable software is much more customizable, also has green screen, video, and touch screen support. I'd already bought the hardware for this booth before finding that software. Unfortunately the equipment is too underpowered (computing wise) to support it, so will spec the next booth for it.
    13,363
    Very cool. Turning out quite well!
    What kind of computer hardward do you have in there? Is it running on Linux?
  1. Bed Hardware
    By Ryan Mooney in forum General Woodworking Q&A
    Last Post: 01-28-2015, 09:01 PM
  2. Hardware help?
    Last Post: 12-20-2013, 07:20 PM
  3. Bed Hardware
    Last Post: 07-12-2012, 08:37 AM
  4. Bed Hardware
    By Ned Bulken in forum New Tools
    Last Post: 05-07-2009, 07:31 PM
  5. hardware
    By Gerry Maul in forum General Woodworking Q&A
    Last Post: 10-18-2007, 09:52 PM
