Results 1 to 9 of 9
Thread: Max Drawer Size
    Jun 2010
    3,220
    Max Drawer Size
    Is there a maximum cabinet drawer size, for width and/or depth, that works properly on Blum runners? How about max weight? For example could I have a drawer that's 3' wide by 3' deep and hold 50 lbs?
    AKA The Rookie
    13,437
    I'm sure there are specs out there...will see if I can locate any. For that large of a drawer and weight, you may consider doing a thicker bottom, like 1/2" ply.
    Edit: Only finding clearance specs, not really anything on drawer size. I think that based on simple physics you could determine if additional slides are needed or not, say if the drawer was 3' tall and top heavy, you may want to have slides at the bottom side and maybe a set towards the top. The trash can and pan pull-outs I did for my kitchen have no problem supporting the weight from the bottom alone with the 100# glides I used.
    Thomasville, GA
    5,992
    Cynthia, I usually go to this site to check drawer slide specs and for the best price. Blum.com is another good source, of course. I've used the "house brand" of slides from woodworker.com for years without any issues.
    Edit: I did a search for large slides and found a somewhat common thread among different brands. For instance, 500lb slides can be found for anything from 12" to 60" in length (drawer depth) but the maximum width is 42".
    Bill Arnold
    Central NY State
    3,374
    I once made a sewing table for my wife, and the requirement was that the drawer hold a yardstick. I forget exactly how wide the drawer was, but ID was obviously > 36". The thing racked terribly, and we gave it away.
    I think that unless you're looking at industrial grade hardware, you need to be careful about going wider than what you usually see on furniture or kitchen cabs.
    If you look at the thread I posted on mappa burl cabinets I did a 48" wide drawer with blum under mounts and they were as smooth as could be with no racking or binding. Each drawer had 2 pulls and you could open the drawer just by using one pull.
    Central NY State
    3,374
    Well Alan, I just looked here:
    http://familywoodworking.org/forums/...ght=mappa+burl
    and I'm still trying to pull my socks back on. Glad to see you had better success than my measly attempt. Were those regular Blum under mounts?
    They were the blumotion which if I remember correctly are the soft close versions with all the adjustments front and back. Glad you posted the link. Thought I did guess I'm getting old timers as another birthday goes by.
    Jun 2010
    3,220
    Thanks guys, I'll study Alan's thread.
    AKA The Rookie
    Independence, Kentucky
    1,354
    +1 on the Blum Blumotion slides They are great and they are made in the USA.
    I get them from www.wwhardware.com
  1. King Size Bed
    By Ted Calver in forum Designs, Plans and Sketches
    Last Post: 12-09-2012, 02:58 PM
  2. Wire size?
    By Al killian in forum Carpentry and Construction
    Last Post: 06-14-2012, 10:24 PM
  3. Drawer Component Dimensions as Function of Size
    By Ken Close in forum General Woodworking Q&A
    Last Post: 10-03-2007, 06:15 PM
  4. Attaching drawer fronts to the drawer.
    By Mark Rios in forum General Woodworking Q&A
    Last Post: 02-27-2007, 04:11 AM
