Results 1 to 5 of 5
Thread: Baltic Birch plywood quality
    I tried dovetail joints in 3/4 inch Baltic Birch plywood for some drawers. The plywood splintered so badly as to be unusable. I have made dovetail joints in solid wood with no problems. Are there different grades of Baltic Birch or can it simply not be done?
    Thanks, DKT
    Oct 2007
    N. Ga.
    15
    Most plywood is going to give you trouble doing router cut dovetails. I've had decent success but only when I use a backer board and a sacrificial board across the face to limit tear out. It also helps to first run the dovetail bit along the full width of the joint making a shallow cut to limit splintering.
    Quote Originally Posted by Dietrich Trenner View Post
    Thanks, DKT
    Don't take this personally because it's just my personal opinion. Even if you make perfect dovetail in BB plywood the just don't look good to me and I only use dovetails in solid wood. For 1/2'' BB plywood I like to make a locking rabbit joint. The locking rabbit is strong and is very sufficient for drawers.
    What Jim said plus your router bits need to be very sharp. And there are different grades of Baltic Birch plywood. If you bought it at a borg, it might not even be true BB.
    May 2011
    So. Florida
    268
    True Baltic Birch or Appleply machines well if a backer board as mentioned is used to prevent blow out. Or, you can hand cut the DT's if you are so inclined.
  1. Baltic birch stateside??
    By Art Mulder in forum General Woodworking Q&A
    Last Post: 11-22-2012, 03:53 PM
  2. Eccentric Baltic Birch Plywood Bud Vase
    By Jim Krager in forum Lathe Project Showcase
    Last Post: 08-09-2011, 09:23 PM
  3. Baltic Birch Plywood
    By Rob Keeble in forum Hot Deals
    Last Post: 11-19-2010, 10:45 PM
  4. Sketchup Baltic Birch Ply Material?
    By Doug Shepard in forum Designs, Plans and Sketches
    Last Post: 12-15-2008, 10:25 AM
  5. Baltic Birch Shortage?
    By glenn bradley in forum Off Topic Discussion
    Last Post: 07-17-2007, 11:19 AM
