Results 1 to 10 of 20
Thread: pipe clamp question
    Jun 2010
    3,220
    pipe clamp question
    When you buy pipe clamps, and it says, for example, "for 3/4" pipe", does the pipe have to be threaded on one end?
    Good Morning Wood Folks from beautiful Courtenay, BC, where we have 2" of snow on the ground.....
    AKA The Rookie
    Independence, Kentucky
    1,354
    Yes the pipe has to have threads on one end , it is best though to have both ends threaded to enable you to use a coupling fitting to make the clamps longer as needed.
    Jun 2010
    3,220
    Thanks Charles. You're the man!
    AKA The Rookie
    17,470
    makes more sense to add on extension rather than have one long piece cynthia,, to a point.. you dont want 4-12" pieces to get a 48" clamp.. so use some logic when getting your pipe
    Jun 2010
    3,220
    Logic? I figured to get 2, 7' and 2, 4'. LOML has to get a piece of metal from a metal guy for something different so I figured I'd use the opportunity for him to get me some pipe for clamps at the same time.
    AKA The Rookie
    Dec 2008
    falcon heights, minnesota
    5,604
    i have threads on both ends of my pipes. then again, i have 6', 4', and 2' pipes.
    benedictione omnes bene
    www.burroviejowoodworking.com
    Jun 2010
    Croton, Ohio (about a half hour NE of Columbus)
    153
    ...Be sure and get galvanized pipe. I have a few that are on black pipe and they've gotten to be pretty rusty.
    May 2009
    Poway, CA, near San Diego
    174
    I've always heard that you should use black pipe. The zinc coating on galvanized is soft and doesn't hold well.
    Bob
    Dec 2008
    5,604
    i've used black pipe now for several years, and not one spot of rust.
    Mar 2011
    Painesville Ohio
    131
    If you go to lowes or home depot buy 12' pipe. They will cut it to size and thread it for free.
    "Its only by minute attention to every detail that you will achieve perfection"
  1. Everything Old is New Again - Pipe Clamp Pads
    By glenn bradley in forum Off Topic Discussion
    Last Post: 08-30-2013, 05:37 AM
  2. Pipe Clamp Pads / Stands
    Last Post: 06-02-2013, 09:04 PM
  3. Rockler pocket hole clamp question
    Last Post: 10-05-2010, 12:37 PM
  4. SketchUp Pipe Clamp Component
    Last Post: 02-09-2008, 10:54 AM
  5. Pipe Clamp Mag Pads
    Last Post: 05-14-2007, 05:38 PM
