Results 1 to 10 of 14
Thread: Workbench Design Question
    Jun 2010
    3,220
    As I read about workbench design, there's one thing I don't understand. Many (most) of the current designs call for a long narrow table, sometimes only 2' wide. How in the world do those folks handle a sheet of plywood on such a narrow table?
    AKA The Rookie
    Thomasville, GA
    5,992
    A workbench needs to be whatever YOU need, not what someone else thinks you need. I don't have a "classic" workbench but I seem to muddle through and get things done. In my case, I wanted the ability to lay a full sheet beside my table saw and slide it over to make my cuts, so that's how I designed my workbench.
    To answer your specific question about sheet goods, some people place a sheet on sawhorses to cut it down to smaller sizes. Some lay it on styrofoam on the floor - whatever it takes to break down the sheet goods.
    Bill Arnold
    5,533
    Cynthia,
    the 2' depth is more about most people's reach... anything deeper and you wind up with clutter just 'out of reach'... DAMHIKT, my benches are 30" or so deep, but I have longer arms and I still get clutter toward the back of them. er, actually I get clutter on all of it... might have something to do with how I work, not the depth of the bench.
    -Ned
    Bellingham
    2,449
    Your classic hand tool bench is narrow. I am working with solid wood and really only need about 12 inches at most of depth. If your intent is to work with plywood, then you would need a large work table to support your work. Remember, the benches purpose is to support the work. If the work is large then you need a larger table. Kind of common sense when you think about it in those terms.
    5,533
    Good point Bill. about three shops ago, I had the luxury of a shop large enough to have a central outfeed/work table in the middle of the shop, it was about 4' x 6' and was right next to the heart of the shop (the TS)... we did all manner of assembly, finishing etc... on it, but we also had nearly 30'x30' of space to work with. my last shop... and my current 'shop'... I broke down sheet goods outside like most people do.
    -Ned
    Constantine, MI
    7,890
    The 'classic' workbench, as bill mentioned, is primarily designed for hand tool use and the basic layout has not changed in hundreds of years. Check out last months Fine WoodWorking magazine for one alternative - one I am seriously considering for my own shop.
    www.wrworkshop.com
    A workbench is not the same as a work table or assembly bench.
    Your use of 4x8 sheets of plywood sounds like it would be better suited to an assembly bench.
    Jun 2010
    3,220
    In the Dec 2011 issue, I don't see anything about workbenches...is it a different one?
    Well, I see your point, but I don't have room for 2 benches, so one will have to serve all purposes. Right now it's 4' X 8', that's too big. I think 3' X 7' will do everything.......
    AKA The Rookie
    Constantine, MI
    7,890
    Quote Originally Posted by Cynthia White View Post
    "Winter 2011-2012" annual tools and shops issue. Sorry.
    Some goo general info HERE
    The power tool workbench is HERE
    www.wrworkshop.com
    Constantine, MI
    7,890
    I disagree. What woodworkers consider a proper bench is very different than that of a metal worker, potter, etc. I think we, as woodworkers, get a bit myopic when talking about benches. The definition needs to open up a bit to include 'benches' that are not traditional hand tool benches such as larger 'tables', etc. Our HS shop classes had work benches that were about 6' square, had four vices, and could accommodate 4 students. Would that not qualify as a workbench?
    www.wrworkshop.com
  1. workbench question
    By Bill McQueen in forum General Woodworking Q&A
    Last Post: 02-06-2012, 05:49 AM
  2. A Workbench Design
    By Bill Satko in forum Designs, Plans and Sketches
    Last Post: 11-26-2010, 03:41 AM
  3. Workbench question
    By Bill Antonacchio in forum General Woodworking Q&A
    Last Post: 11-06-2007, 03:26 PM
  4. Adding to workbench top question
    By Allen Bookout in forum General Woodworking Q&A
    Last Post: 02-24-2007, 05:01 PM
  5. workbench Design Question
    By Mike Gabbay in forum General Woodworking Q&A
    Last Post: 01-11-2007, 12:46 AM
