Results 1 to 8 of 8
Thread: More Fun with the Worksharp 3000 - Spokeshave Jig
    There was a lot of spokeshave work on a recent project and a touchup was in order. I took a piece of 3/8" thick x 2-7/8" wide ash, squared it up and cut a slot using my tenoning jig. I drilled two 5/32" holes, countersunk them and tapped a pair of 10-24 machine screws into them. Be very precise about the screw locations as they act as the stop for the cutter to assure a square edge. A snug with a screwdriver grips the cutter.
ID:	62800 Click image for larger version.
ID:	62801 Click image for larger version.
    I set the micro bevel on a diamond plate I had handy and run it on the Worksharp at 3600 grit and on the honing plate, each for a few seconds. The results looked good and a few test passes tell me this will meet my needs. Quick, easy and repeatable; that's what I need when it comes to sharpening.
ID:	62803 Click image for larger version.
ID:	62804 Click image for larger version.
ID:	62805 Click image for larger version.
    17,472
    are those screws threaded into the ash glenn? or just holes.. looks like its threaded to make a squezz on the blade..
    13,360
    A tiltbox to set the angle? Brilliant! Of course the whole thing is a very nice way to sharpen a hard to hold blade, but the tilt box is a great idea.
    Through holes on the countersunk end, threaded into the other. As you describe, this is what grabs the iron. I was shocked that it worked so well. The screws are long enough to allow the addition of nuts should the threaded ash eventually fail. I have some jigs with machine screws threaded into hardwood that I have been prepared for a failure of for a few years though .
    Oliver Springs, TN
    1,726
    WOW! That's a great idea using the angle gauge to set the angle. I'll have to file this one for later use.
    Jun 2007
    4,944
    Now I know where all of my brains leaked to---Glenn got 'em.
    Enjoy,
    JimB
    VOTING MEMBER
    May 2009
    Syracuse, Nebraska
    669
    After threading wood I have squirted super glue in the threads and let it dry. Reinforces the wood for more durability.
    13,440
    Nice setup and use of the tilt box. MDF threads nicely as well. A good part of my cnc is held together using machine screws threaded into the mdf, nothing more. Roger's suggestion of super glue works well also.
  1. Inexpensive Diamond Plates for Worksharp 3000
    Last Post: 02-12-2014, 10:47 AM
  2. Worksharp 3000?
    By Ken Fitzgerald in forum New Tools
    Last Post: 05-14-2012, 12:21 AM
  3. Worksharp 3000 ordered
    By Matt Ducar in forum New Tools
    Last Post: 04-07-2012, 04:19 PM
  4. If your using the Worksharp 3000
    By Bart Leetch in forum Neander Woodworking Q&A
    Last Post: 05-07-2008, 05:29 AM
  5. Nova DVR-3000 and Nova 3000 bed extention close out
    By Stuart Ablett in forum General Woodturning Q&A
    Last Post: 12-20-2007, 04:27 AM
