Results 1 to 10 of 19
Thread: Seeking feedback and suggestions in order to deal with a BIG GOOF that I just made
    Toronto, Ontario, CANADA
    2,332
    One of my many current projects is making a lamp (as described in the thead http://familywoodworking.org/forums/...e-Build-thread)
    About an hour ago, I finished routing and chiseling the rabbets into which the glass pieces for the shade are to be inserted.
    I did a good job on the rabbets, BUT I placed then on the outside rather the inside of the frames.
Name:	Prairie Lamp nn -I cut the rabbets for the glass on the wrong side of all four lampsieeices -sma.JPG
    The screwed up oak frames are towards the top of the photo. The properly built pine experimental frame is at the bottom. The glass is supposed to be held in place inside the wooden frame pieces with small strips of 1/4 round.
    What to do?
    1) I could make new frames, but that would take at least 6 hours.
    2) I could make some molding such as the sample shown in these two pictures.
Name:	Prairie Lamp nn -Cross section view of sample corrective trim piece -small.JPG
ID:	62810 Click image for larger version.
Name:	Prairie Lamp nn -Sample corrective trim piece in view -small.JPG
    That would take an hour or two but might make the lamp look "funny".
    3) I could follow some other suggestion made by you.
    Please respond ASAP becuase I want to get back to this project tommorow.
    Cheers, Frank
    Sep 2007
    Plainwell, Michigan
    4,857
    That a bummer Frank but as nice as a job you are doing on it and with that nice glass and that it is on the outside, I would be inclined to make new, Sorry...
    Oct 2009
    Dennison, MN
    512
    Make em' again. Its only six hours.
    "Do, or do not. There is no try."
    -Yoda
    5,322
    Frank,
    if you 'kluge' them, you'll never be happy with them - no matter how good they'll look to others. Bite the bullet, and make them again.
    Yorktown, Virginia
    5,017
    Before I made new frames, I would be tempted to see how a molding such as the one you show in the second picture would look if you rip it in half or a little less than half... enough to lock the glass in place and still cover a quarter of the frame. That would give the frame kind of a stair step look and provide a little visual interest. Be worth a try just to see.
    10,604
    I agree. Give it a shot.
    2,784
    Is there a reason you can't just turn the outside to the inside? Are they miter cut? (can't tell from the photo, sorry) If so, is there enough meat to miter cut them again the right direction so you could turn them around? Could you cut a piece that would fit at the edges that would in effect make the miter cut disappear. or even cut the miter off and use a cut piece as the new corner?...could be the same wood or a contrasting wood, or the same wood stained a different color. If not, I'd call them my templates, throw the pine one away, and start over. Jim.
    Coolmeadow Setters...
    Exclusively Irish!
    12,260
    I aint got any idea but i like Jims the best. Could add a great character if you could get a contrasting strip down the middle of the joints.
    NH
    4,006
    If it was me and I was going to run with them I would make the molding for the outside out of a very contrasting wood like say walnut. At the same time I would start the new set. This set is not what you planed on building but it can be saved and a new set done the way you planed done up. Of course you realize that buy finishing this set up this way it means you have to build a new lamp for them.
    You could mix in some of that walnut into the lamp to match the shade.
    Stupid hurts.
    Dec 2008
    falcon heights, minnesota
    5,610
    make new ones. if you screw up trying to fix these, it would only be worse, and you'll have to make new ones any way.
    benedictione omnes bene
    www.burroviejowoodworking.com
  1. Seeking suggestions - repairing a cracked seat in a pew
    By Art Mulder in forum General Woodworking Q&A
    Last Post: 06-28-2013, 12:16 AM
  2. Made to order
    By Pete MoncrieffJury in forum Lathe Project Showcase
    Last Post: 04-20-2009, 12:02 AM
  3. Desperately looking for some feedback!!
    By Toni Ciuraneta in forum Designs, Plans and Sketches
    Last Post: 04-15-2008, 06:16 AM
  4. one goof then another makes for a bad day
    By John Daugherty in forum Off Topic Discussion
    Last Post: 02-10-2008, 05:38 AM
