Results 1 to 10 of 10
Thread: Radiused Laminated Platform Bed/Dressers
    May 2011
    So. Florida
    268
    These pieces were all done with a plywood substrate, with radiused fronts and edges, laminated in a gloss high pressure laminate (like Formica).
    Jan 2011
    3,798
    Cool stuff!!!
    10,604
    Wow, that's pretty interesting
    17,471
    that is definitly a nice job,, but its not my cup of tee for style,, that radius work is excellent mike..how did you keep it in place while it was setting up?
    May 2011
    So. Florida
    268
    The radius material I get in lengths of 6'-8', either in MDF, plywood, or Poplar depending on the supplier, I don't make them. The corner rounds can be splined and glued together to make half circles. The curves are attached to flat stock, so they don't get out of shape. I use contact cement for laminating with HPL (like Formica) which I use postforming laminate that bends very easily. Paper backed veneer can also be used the same way. So, there's no "keeping it in place" per se. Thanks for the interest.
    May 2011
    So. Florida
    268
    Thanks to those that commented and took an interest.
    Thomasville, GA
    5,992
    Mike, I have to agree with Larry that it's not my thing, but I can see the appeal to others. During brief tenure in a couple of cabinet shops, I used some commercially-made cylinders like you show for projects and they're terrific for specific applications. The project you show is great! Not anything I'd have in my home, but great as an example of what we, as woodworkers, can accomplish. Good job!
    Bill Arnold
    13,357
    Definitely looks like a challenging project. It looks very well executed, and quite well done!
    Mike you certainly do a lot of interesting stuff, fantastic work, thanks for taking the time to show us!
    12,247
    Great job Mike pretty interesting design and style? How did it come about? Had customer seen it somewhere or what?
    Well executed. You know you good when you can take on a job like that and so successfully finish it. Well done, I bet customer was delighted.
    Now i would have preffered the log cabin look but with natural logs
  1. Twin dressers project progress
    By Dewayne Baker in forum General Woodworking Q&A
    Last Post: 02-08-2016, 01:11 AM
  2. PV glue for bent laminated parts of furniture?
    Last Post: 03-21-2015, 08:15 AM
  3. question on laminated wood for bowl
    By Drew Watson in forum General Woodturning Q&A
    Last Post: 11-16-2009, 08:24 PM
  4. Cutting Laminated Counter Top..***Final Stages***
    By Greg Cook in forum Carpentry and Construction
    Last Post: 03-11-2007, 04:30 AM
  5. back cutting small radiused mouldings on the shaper
    By tod evans in forum Jigs and Fixtures
    Last Post: 11-10-2006, 05:44 PM
