Results 1 to 5 of 5
Thread: using latex paint
    Jun 2010
    3,220
    using latex paint
    I've read that you can take latex paint, water it down and apply it to a project to get an exact coloring or streaking or whatever effect you want. I have 2 questions.
    1. Has anyone ever done this?
    2. If I did this, could I put a water-based poly over it?
    Thanks!
    AKA The Rookie
    Austin, Texas
    1,448
    Keep in mind that paint is different... Latex ceiling paint has high reflection and good coverage, but does not have wear resistance. Latex wall paint has better wear rating (but often takes 2 coats for coverage) and better dirt resistance (little tooth). Latex primer has good coverage but also good "tooth" to hold the final paint. Latex trim paint has excellent wear resistance and easy cleaning. Latex house paint is flexible to expand and contract with the weather, but has minimal abrasion resistance. Latex deck (floor) paint... well, you can follow...
    A common mistake is to say, I can use that left over latex whatever paint as a primer for my painted furniture. Okay, but will that leftover paint have good coverage and tooth and provide a hard base for the finish? And so forth. So just grabbing some latex paint and saying "sure it has the right color" doesn't say it is a good primer or surface for what you are building.
    I recently saw where someone wanted a "brushed finish" look on some fine cabinets (why???), and the solution was to brush on some latex, to give it brush strokes, then apply the final hard finish (lacquer, varnish, or whatever).
    So can you do it? Yes. But the finish you get isn't the same as the finish you would get by coloring the regular finishing material.
    Charlie Plesums, Austin Texas
    10,604
    My uncle who made all the cabinets in the old house we lived in used a watered down latex paint to wipe on the cabinets like stain then put poly on top. Wasn't quite my style but they looked and wore very well.
    13,447
    I have used latex paint then coated with the minwax water based poly, it worked well. I mostly did it as it was on some child rockers and being that they would be passed down, I didn't want to worry about any latex allergies. Both rockers are still holding the finishes well.
    Jun 2010
    3,220
    Thanks folks. I really just wanted to know if it could be done.
    AKA The Rookie
  1. OSB Paint Coverage
    By Rich Aldrich in forum General Woodworking Q&A
    Last Post: 09-27-2009, 12:18 PM
  2. Using an HVLP Set up to Spray Latex Paint...?
    By Stuart Ablett in forum Finishing School
    Last Post: 02-04-2009, 06:32 PM
  3. Paint help
    By Jeff Bower in forum Old Iron
    Last Post: 07-31-2007, 01:37 AM
  4. Paint help
    By Jeff Bower in forum General Woodturning Q&A
    Last Post: 07-30-2007, 08:50 PM
  5. Help Stu Paint his saw!
    By Art Mulder in forum Finishing School
    Last Post: 06-06-2007, 01:36 AM
