Results 1 to 5 of 5
Thread: Stair case routing
    Hilliard, OH
    9
    Stair case routing
    Hello I am new to this forum, I have been doing light woodworking for about 10 years. Previously I was in the remodeling field. I have a question for stair builders. If this is in the wrong place I am sorry. I am looking for a jig to route out the stringers for a staircase that I am building for my house. Is there a company in the usa that makes these or are they all in the UK. Or if anyone has a drawing to make a jig I would appreciate it.
    Thanks
    Fred Pilkington
    fred, i prefer to make my own on the rare occasion i do stairs.....i like using 3/4 baltic birch. if you join your treads-n-risers with a 1/2x1/2 tongue-n-groove, then allow for a 1"in12" wedge you`ll have a pattern to cut, then try your parts before affixing the fence.......it`s much easier to build than to discribe ......but if like me you prefer 1 1/2" thick treads and 1 1/4" thick risers the ready made jigs won`t fit `em anyway.........a set of housed stringers will outlive you and i! tod
    Hilliard, OH
    9
    Thanks Todd
    Todd: Thanks I was not sure what the wedge dimensions were. I have built a few of the cut stringer stairs before. I am using 1 1/2" treads. I will have to play in the shop with the jig. .
    Thanks
    Fred
    Hilliard, OH
    9
    Thanks Steve
    Steve:
    Thanks for the information. I had seen the trend jig from Trend UK. also the other aluminum jig for 600.00. I thought I would try to make one. Since this will probably be the only one that I do. Good information though. I appreciate it. My wife had to like the toughest one to make. I may even get a new router out of this one. . What size router bit do you recommend for a template? I will probably get the 3 hp porter cable.
    Fred P
    fred, i like to use 3/4" top bearing bits....and i prefer to use two routers with different length bits.....the first cut when using a 1" top bearing bit with a 3/4" thick jig is slightly over 1/2" deap then before moving the template take the second router with a 1 1/2" bit to finish trenching to a full inch.....this gives nice deap mortises for the treads-n-risers pluss plenty of meat for your wedges to engage.....tod
  1. Vinyl Stair Rails
    Last Post: 07-12-2013, 05:20 PM
  2. A Replacement Stair Baluster
    By Roy Bauman in forum Lathe Project Showcase
    Last Post: 08-23-2011, 01:01 AM
  3. Stair Question
    By Vaughn McMillan in forum Carpentry and Construction
    Last Post: 08-03-2011, 08:25 PM
  4. Stair cases
    By Al killian in forum Designs, Plans and Sketches
    Last Post: 12-31-2010, 03:21 AM
  5. Installing Stair Treads
    By Darren Wright in forum Carpentry and Construction
    Last Post: 02-27-2010, 03:25 PM
