Results 1 to 7 of 7
Thread: Cross slide vice
    The Heart of Dixie
    4,268
    Cross slide vice
    I need a cross slide vice for use in my drill press. Not a machinist quality vice either. I find I am regularly making brackets for the kayaks and need a better/quicker way and this would improve my quality as well.
    I see a couple at Harbor Freights web site. I looked on EBay and was surprised to see some cheaper but always leery when it's that cheap.
    So recommendations? Trying to stay around 50-75$.
    Custom built boats and Kits
    Bellingham
    2,449
    I believe that Grizzly has a large selection to choose from.
    11,833
    I have a Grizzly that was about $40.00. It is kinda 'sloppy'. Next time I would look for something that doesn't shift around so much.
    Toronto, Canada
    276
    I have a Busy Bee (BB is somewhat similar to Grizzly) cross slide I use on the wood lathe, for wood & metal. First thing I did was disassemble, clean, and graphite lube before use
    It's sloppier in some areas of travel, but overall not too bad after adjusting the gibs.
    The Heart of Dixie
    4,268
    The Harbor Freight had a scale on the vice and the Ebay versions had a dial on the handle. Slop is a good reason to go with Harbor Freight unit, backlash in the adjustment wouldn't matter. Scale on the vice would show the actually movement and I am dealing with 1/16" increments. I will check Grizzly latter.
    Central NY State
    3,374
    I have an old HF, got it with my DP maybe 20-25 years ago. It works just fine. Needs to be clamped down, but for my needs, it has been quite accurate.
    The Heart of Dixie
    4,268
    Drove to Huntsville last night and picked up a Harbor Freight vice. Looked at in the floor and for drilling holes it looked perfect for my needs. I will take down to the shop latter and take it apart, clean, debur and give it a good cleaning and adjusting. (the one on the floor was sloppy loose). I am going to mount in on a base and I want to set it up so I can just drop in on the drill press and go. Assuming I can do what I am thinking I will post some photos latter in the week.
  1. Slide top cove boxes
    By michael stafford in forum Flatwork Project Showcase
    Last Post: 11-14-2014, 10:12 PM
  2. Need hardware (slide) help
    Last Post: 09-04-2011, 12:53 AM
  3. Drawer Slide Install
    By Rob Bodenschatz in forum General Woodworking Q&A
    Last Post: 12-12-2010, 04:30 AM
  4. Drawer slide help needed.
    By Tom Niemi in forum General Woodworking Q&A
    Last Post: 11-02-2008, 02:44 AM
  5. Auuuuuugh! *first slide down the slope*
    By Ned Bulken in forum Lathe Project Showcase
    Last Post: 10-08-2007, 02:00 AM
