Results 1 to 5 of 5
Thread: Table top glue up
    Table top glue up
    I'm starting with a table top for a Sideboard. I'm using African Mahogany 1 inch thick and 6 inches wide. The top is approximately 4 feet long by 2 feet wide. Should I cut the width of the boards in half (3 inches wide) and then glue them together to address cupping and other wood movement? I plan on using breadboard ends.
    Thanks, DKT
    10,604
    After milling the boards flat and square I would glue up the 6" pieces alternating the rings up and down. You won't have a problem especially with the bread board ends.
    I would leave them at 6 inches and glue the board up for the best appearance without regard for the growth rings.
    Central NY State
    3,374
    I'm with Richard on this. Go for the best grain and appearance.
    17,472
    another vote for best appearance, but make sure you have dry lumber!!!! and then the breadboard ends will control your movement in width.. you can get cupping with the boards going in a best appearance set up if the lumber hasnt been acclimated to your area and shop first.. i had a top on a end table cup on me after glue up that was done for appearance it was corrected by rewetting the top and clamping it down flat actually past flat to allow for spring back..but it stayed after that in the position i wanted i hadnt let it acclimate in the shop first trying to hurry the project along along and paid for it ..
  2. What glue
    By ken lutes in forum General Woodworking Q&A
    Last Post: 03-11-2010, 01:42 AM
  3. What glue to use?
    Last Post: 05-03-2009, 11:26 PM
  4. Glue line on router table
    Last Post: 01-26-2008, 08:16 PM
  5. OK, now the glue?
    By Chuck Hanger in forum Turning Tool Questions and Show & Tell
    Last Post: 04-27-2007, 03:12 AM
