Results 1 to 10 of 17
Thread: anybody ever make concrete countertops?
    Oct 2009
    Dennison, MN
    512
    Got a bid back this morning for granite. Almost $4k for my little kitchen, I can't swing that.
    If anybody has advice, I'm all ears.
    "Do, or do not. There is no try."
    -Yoda
    Dec 2008
    Portland, Oregon
    1,898
    I've never done it myself, but have seen them do it on several home-improvement tv shows, here's a link to several videos
    Click Here
    Jesus was a Woodworker
    13,363
    I made a small one. http://familywoodworking.org/forums/showthread.php?19181-Concrete-Counter-Top
    It was a fun project. But it was just for a utility sink in a bathroom. It's still holding up well with no cracks.
    1) Be ready, it will be heavy.
    2) Make sure to really vibrate the heck out of it to get the airbubbles out. I had some little voids in mine I filled in
    3) Get a real polisher. I used some little disks with an air grinder and it worked out, but if you do something larger, you might need something bigger.
    4) It will probably be thicker than the normal counter, so make sure you figure out how to attach the sink to it before you start.
    5) I used the crack resistant concrete and a lot of iron oxide powder and it worked fine. If you are doing a real kitchen, you might want to check out the special counter top additives.
    North West Indiana
    6,099
    I knew someone here had done one. Brent, that's right!!
    Take a bunch of pictures and take all of us along on the journey if you decide to do this! Also, for large counters, will the cabinets need to be reinforced?
    Jon
    Oct 2009
    Dennison, MN
    512
    Quote Originally Posted by Jonathan Shively View Post
    My stuff is so over built I'm not remotely concerned with how much weight is on them.
    I can't go thicker than 1-1/4. I have a window that sits really low and the top will be going back to it and act as the jamb, then the casing and jamb extensions on the side will die into the counter top.
    I'm debating whether to pre-cast them, or to pour them in place. I won't be able to polish them well on site without destroying everything else in there. A buddy poured his own a bunch of years ago and his had a bunch of texture, it was kinda cool, but......
    -Yoda
    17,475
    but what about your floor under your cabs karl
    13,363
    Mine are pretty much at exactly 2" thick. Overkill I think. You could always do a test run of a 2'x2' slab at 1 1/4 to see how it works for you.
    After polishing with the diamond pads and putting a coat of gloss poly on mine, they have a similar texture to the silestone we have in the kitchen. The different rock grits give it a very interesting appearance. I actually really like the way it looks and turned out, even if it spends all it's time as just a slop sink counter.
    Quote Originally Posted by Karl Brogger View Post
    Jun 2010
    3,220
    Karl, could I make a suggestion? How about large granite tiles? With almost no seam/grout line, they look beautiful for a fraction of the cost.
    AKA The Rookie
    North West Indiana
    6,099
    Quote Originally Posted by Cynthia White View Post
    Interesting idea, pour the concrete countertop and press the large granite tiles into it? Interesting.
    Jon
    Jun 2010
    3,220
    Jonathan, no. I mean no concrete, but a granite tile counter. It doesn't look like tile--it looks like granite because the tiles are big and you have almost zero grout line.
    AKA The Rookie
  1. Wood countertops, how to?
    By Brian Altop in forum General Woodworking Q&A
    Last Post: 04-23-2011, 02:39 AM
  2. Friend wants to make end grain countertops
    By Alan Bienlein in forum General Woodworking Q&A
    Last Post: 11-15-2010, 02:40 AM
  3. Milling Corian countertops
    By Tom Niemi in forum General Woodworking Q&A
    Last Post: 07-15-2010, 04:15 PM
  4. Stuipd Question-Countertops
    By Travis Johnson in forum Carpentry and Construction
    Last Post: 08-19-2007, 12:03 AM
  5. Shop Countertops
    By Tommy Squires in forum Carpentry and Construction
    Last Post: 05-28-2007, 04:01 PM
