Results 1 to 4 of 4
Thread: Template Routing Jig - v2
    I had to do some longer template routing on the last couple of projects. It figures that as soon as I got done with the current projects template requirements, a sale on the auto-adjust Besseys would come along. So, time for version 2 even though it may not see much use till the next project.
    Here's the version 1 jig and the 4th clamp I just picked up. I grab a piece of ply and a piece of oak out of the scrap bin. I upped the base to 1/2" as the 1/4" base often flexed and made things fussy. Machine both pieces of wood square and screw one to the other.
Name:	template routing jig v2 1.jpg
ID:	63372Click image for larger version.
Name:	template routing jig v2 2.jpg
    Select your outer most clamp position and mark it. Bessey was good enough to make the holes on 1-1/2" centers so I can use setup blocks and just keep stepping off the holes. I learned on version 1 that having multiple positions is a good thing so I made a bunch.
Name:	template routing jig v2 3.jpg
ID:	63374Click image for larger version.
Name:	template routing jig v2 4.jpg
ID:	63375Click image for larger version.
Name:	template routing jig v2 5.jpg
ID:	63376Click image for larger version.
Name:	template routing jig v2 6.jpg
    I add the larger pivot foot to the new clamp and I'm all set. I replaced the top nuts for the foot adjustments with knobs back before I had the auto-adjust clamps. With the new clamps you almost never adjust the feet but, since the other three were already that way, I matched them. The little red caps on the ends of the threaded rod for the feet keep you from smacking yourself in the knuckles when disengaging the clamps DAMHIKT
Name:	template routing jig v2 7.jpg
ID:	63378Click image for larger version.
Name:	template routing jig v2 8.jpg
    17,472
    thanks glenn.. so these are the wide gapped ones
    These are the low profile ones. So, I guess you would call them the narrow ones(?). Bessey STC-HH50, 2" opening is what I have. High profile ones are STC-HH70, 2-3/4" opening.
    17,472
    ok i got it this time glenn,, hadnt looked at the model numbers just the size reference.. sometimes we read what what we want to see and not what is there
  1. Insert Bits for Template Routing?
    By Ted Calver in forum New Tools
    Last Post: 04-05-2015, 11:41 PM
  2. Routing Downhill
    Last Post: 02-16-2014, 11:07 PM
  3. Routing Guide
    By Darren Wright in forum General Woodworking Q&A
    Last Post: 04-23-2013, 08:16 PM
  4. Template routing question.
    By Brent Dowell in forum General Woodworking Q&A
    Last Post: 01-28-2013, 09:57 PM
  5. CNC ROUTING ??
    By Leo Voisine in forum Off Topic Discussion
    Last Post: 02-13-2009, 05:21 PM
