Results 1 to 6 of 6
Thread: I turned some yo-yos
    Toronto, Ontario, CANADA
    2,332
    (part 1 of 2)
    Sunday Dec 4:
    I started to make yo-yos for three children on my Christmas list but ran into a snag. With luck, they will be finished tomorrow. Lee Valley sells a kit (catalogue number 88K161) that can be used to make a very good yo-yo and one needs a lathe for the project.
    Mack Cameron agreed to let me use his lathe today and Don McFarland his neighbour in Brooklin agreed to help to train me.
    I have not used a lathe since high school and the lathe that I used then was a metal lathe.
    In preparation, I cut blocks from four different types of hardwood –cherry, walnut, maple, and jatoba then drilled a hole (35mm by 10mm) into each.
Name:	Turning yo-yos 01 -Drilling 35 mm wide 10mm deep hole into with a brass hub is to be glued -smal.JPG
    A brass hub from the kit was epoxied into each hole then eack block was cut roughly into a circle on my tabletop bandsaw:
Name:	Turning yo-yos 02 -Sort of rounding one side of yo-yo using bandsaw -small.JPG
    Here is a photo of all the sides that I prepared before visiting Mack:
Name:	Turning yo-yos 03 _sides for four yo-yo using four different woods ready for turning -small.JPG
    Mack started turning but soon let me take over:
Name:	Turning yo-yos 04 -Mack Cameron rounding a walnut side -small.JPG
ID:	63390 Click image for larger version.
Name:	Turning yo-yos 05 -Frank rounding a walnut side with Mack looking on -small.JPG
    I found the turning to be quite straightforward and made fewer mistakes than I expected to. After turning the side to the shape and size that I wanted, I sanded the wood starting at 150 grit and working right up to 600 grit right on the lathe (at a slower speed).
Name:	Turning yo-yos 06 -Frank sanding a walnut side -small.JPG
    The walnut sides looked really good:
Name:	Turning yo-yos 07 _two walnut side turned, sanded, waxed, and polished -small.JPG
    But, with the axel mechanism in place, they were too far apart:
Name:	Turning yo-yos 08 -The sides are too far apart -small.JPG
    What was the problem?
    Upon closer examination, Don and I figured out that I had glued all the hub mechanisms into the wood blocks upside-down:
Name:	Turning yo-yos 09 -The reason that the sides are too far apart is that I installed the brass hub.JPG
    There was nothing I could do except to split all the blocks apart with a chisel to extract the hubs
Name:	Turning yo-yos 10 -The sides were split apart in order to extract the brass hubs -small.JPG
    clean, the dried epoxy off the hubs as best I could, make new blocks, and glue the hubs into those blocks with the proper orientation. I did all that at home this evening and will be going back to Mack’s place tomorrow in order to try again.
    Cheers, Frank
    2,332
    (part 2 of 2)
    Monday Dec 5th:
    I finished three yo-yos at Mack’s place on Monday and it took me about four hours to do so. I sure wouldn’t make any money at that pace. I ended up one making the cherry, maple, and walnut versions. I turned the jatoba one a bit but ran out of time. Also I don’t really like to look of jatoba and, if I decide to finish it in the future, I might find that the yo-yo is too heavy.
    The two hubs are joined with this axel assembly (which includes a ball bearing among other sub-parts):
Name:	Turning yo-yos 11 -About to insert an axel -small.JPG
    I managed to brand part of my name onto an inside surfaces before assembling the yo-yos:
Name:	Turning yo-yos 12 -I managed to brand part of my name onto an inside surface -small.JPG
    Finally, I got to test a yo-yo –and I am happy to be able to report that it performs better than any yo-yo that I used in the past.
Name:	Turning yo-yos 13 -Frank testing a yo-yo -small.JPG
    Here is a photo of the three yo-yos that I finished:
Name:	Turning yo-yos 14 -Three completed yo-yos -small.JPG
    Cheers, Frank
    Goodland, Kansas
    4,834
    Looks like you had fun with the guys Frank. Hey that is all a part of learning. I still do things like that. Post your yo-yo's when you have them finished.
    Bernie W.
    13,361
    A project and a meet up! That's great!
    And I'm no pro at the yo yo, but I do love those ones with the 'intelligent' hubs... Very nice...
    Jan 2011
    3,798
    I see the ups & downs didn't stop you from creating some beauty's...nicely done & kudos to your 'families' helping hands!
    12,260
    What a cool present Frank. Good of Mack to let you use his lathe. Must have been a real pleasure learning on a great machine line that. Wow just ocurred to me that was all Canadian...machine, yoyo parts and lessons.
  1. I need something turned
    By Rennie Heuer in forum General Woodturning Q&A
    Last Post: 07-27-2015, 11:55 AM
  2. First turned box
    By Ned Bulken in forum Lathe Project Showcase
    Last Post: 10-05-2014, 06:51 PM
  3. Turned My First .............
    Last Post: 06-01-2010, 09:26 PM
  4. turned box
    Last Post: 07-12-2008, 11:33 PM
  5. Turned another pen
    By Ed Nelson in forum Lathe Project Showcase
    Last Post: 05-21-2008, 03:50 PM
