Results 1 to 10 of 11
Thread: Inset drawer spacing
    17,474
    for some its old hat and others they avoid it like the plague,, well here is a tip for making just alittle easier to asseble a drawer frt with the right spacing each way.. after you have got the drawer frt sized correctly for the allowance you want then take some plastic laminate scraps and cut them to a manageable size i use 2x3.5 and then use one or more to make it fit as you like.. if you want a small gap i take one and just add layers of blue tape just make two the same size for the sides and for the bottom spacing.. works great for me..
Name:	drawer spacing 001.jpg
ID:	63561 Click image for larger version.
Name:	drawer spacing 002.jpg
    oh and for us old folks we need to write down the wraps so that we dont mix them up
    And add a couple of drops of hot melt glue to the back side of the front to temporarily attach it to double check the fit before you permanently attach it.
    new york city burbs
    10,188
    I use pennies to space and double sided tape to hold front in place.
    I like the plastic spacers, much easier for us old folk to handle.
    Human Test Dummy
    Constantine, MI
    7,891
    And they're free at any Lowes or Home Depot. I think they call them 'Formica samples'.
    We all die. The goal isn't to live forever; the goal is to create something that will. - Chuck Palahniuk
    www.wrworkshop.com
    Sep 2007
    Plainwell, Michigan
    4,857
    Much cheaper than the pennies I used for alignment Actually quite the good idea and adjustable
    10,604
    Great idea Larry
    Thomasville, GA
    5,998
    Good idea, Larry! I always seem to have shorts of edge-banding, both 1/8" and 1/16", that I keep in a coffee can for that purpose. I'll have to check on the laminate "samples" the next time I'm at Lowe's.
    Bill Arnold
    17,474
    to me the adjustment factor is key. unless i am the only one that takes one more cut or planes one more swipe that changes things alitle..works for any type of spacing allowance procedure..
    Oct 2009
    Dennison, MN
    512
    For sizing I make one corner fit tightly, then i just use a scriber to set my gaps. I just make two marks on the side, and two on the top and run it on the edge sander and sand to the lines.
    For mounting I use two tapered shims and I just eyeball it. Then nail it from the backside. If I can't get at the backside I use double sided tape, but its not my favorite way to go.
    "Do, or do not. There is no try."
    -Yoda
    Oct 2007
    Nova Scotia, 45N 64W
    1,247
    I knew an old trim carpenter who used to hang doors using the thickness of a dime for reference. His boss questioned him on a fairly wide gap one time. "I didn't have a dime", says he, "so I used two nickels there"
  1. Stair construction and tread spacing
    By Brian Shepley in forum General Woodworking Q&A
    Last Post: 02-28-2010, 01:20 PM
  2. Dog Hole Spacing
    By Mike Gabbay in forum Neander Woodworking Q&A
    Last Post: 11-28-2007, 07:38 PM
  3. Drawer Spacing Help!
    By Matt Dunlap in forum Designs, Plans and Sketches
    Last Post: 09-11-2007, 01:49 AM
  4. Using Drawer Slides With Inset Drawers - Is It A Nightmare?
    By Jeff Wright in forum General Woodworking Q&A
    Last Post: 11-30-2006, 03:39 PM
Tags for this Thread
