Results 1 to 9 of 9
Thread: G0690 / G06901 Owners - A Fence Question
    Coulda swore I asked this awhile back but, cannot find the thread using search . . . I shifted the large tube on my Beisemeyer over one set of holes thereby gaining 10" of rip capacity. Is this possible on the Grizzly fence setup for the G0690/691?. It seems that it would be even if a little drilling and tapping were required. Or, with the current sale price would you just buy the G0691 and cut the rails down if required?
    A little help ;-)
    17,472
    i remember the question glenn,,, someone had just got new griz table saw.. i believe they done the same as you did.. but cant remember the thread either"(
    2,784
    Yeah, I answered that thread. Did it go POOF in the upgrade?? I did exactly that with my 691. I have about 63" to the right of the blade now. Built a new extension table to cover the extra space.Click image for larger version.
Name:	DSCN2712 691 saw front.jpg
ID:	63596 I can actually rip maybe up to 1" to the left of the blade, but never will. I had to drill one hole in the cast iron to make this happen. Jim.
    Coolmeadow Setters...
    Exclusively Irish!
    Dec 2008
    Portland, Oregon
    1,898
    I moved my fence tube over also after seeing a picture of your tablesaw glenn, I have the same Craftsman as yours. Worked great.
    Jesus was a Woodworker
    17,472
    Quote Originally Posted by Jim O'Dell View Post
    i knew i saw a putty cat ,,i did i did
    2,784
    Yeah Larry, you saw that putty tat in person! Jim.
    Exclusively Irish!
    17,472
    guess that file cabinet up stairs still works alittle yet
    Thanks all. I knew Jim had a G0691 and thought I had gotten an answer to my question before. I wanted to confirm my memory (always a good idea for me) and couldn't find the thread. What I am factoring in to the many, many elements of a decision that may never result in a purchase is; if I went with a G0690 or G06901, should I shift the tube or get the 691 and cut them down if required? At the current sale price the difference is only $55 and you get the extension legs so, if I decide soon this is moot. I am going to PM Jim with other questions and will post stuff here if I think it will be of value to others.
    17,472
    yeah he only tells us what isnt classified info for those who dont have sufficient clearance,, you know how those gov types work..
  1. Incra TS Fence Owners
    By Paul Douglass in forum Jigs and Fixtures
    Last Post: 02-07-2015, 02:02 AM
  2. Question for the MOD's or owners
    Last Post: 12-30-2011, 11:16 PM
  3. Replies: 4
    Last Post: 07-08-2011, 04:34 AM
  4. Question for Delta owners
    By Bill Simpson in forum General Woodworking Q&A
    Last Post: 02-27-2009, 05:22 PM
  5. A question for laser owners
    By Dale Johnson in forum Off Topic Discussion
    Last Post: 02-14-2009, 01:24 AM
