Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Changing jointer blades
  1. #11
    NH
    3,355
    I've got one of these little magnetic jigs. Makes the whole thing pretty easy.
    Attachment 63621
    That's where my knife went you can send it back any time.
    No really there is one of them in my shop some where
    Dragon's Paradox
    Stupid hurts.
  2. #12
    May 2009
    Syracuse, Nebraska
    612
    I use a magnet setup too. Got a dial indicator left over from my previous life as a Tool & Die Maker, but don't use it much. You can wear yourself out getting too accurate. Sorta like using 15,000 grit abrasive for sharpening. Overkill.......that's a good description.
  3. #13
    Oliver Springs, TN
    1,190
    Here's my shop made knife setting apparatus. It's obvious that this is an extremely high tech device. I used some 1" mdf scrap, 4 rare earth mags, and two 3/8 12" pieces of aluminum rod. I have some other mags that weren't as strong as the rare earth's on the opposite side that was a failed attempt. I switched to the rare earths and it worked great.
Name:	jointer jig 024.jpg
    The way it works is I found top dead center for the jointer knives and scratched a line that corresponds to that on the fence. It's hard to see in the picture but it's there.
Name:	jointer jig 025.jpg
    I then drew a line that corresponds to the center of the magnets and I align it with the line on the fence. The mags in the first pic aren't the rare earth mags, they are from my first attempt. The second shows the rare earths.
Name:	jointer jig 026.jpg
ID:	63639Click image for larger version.
Name:	jointer jig 022.jpg
    Here's how it works. I stick the jig on the outfeed side of the jointer and align the mark on the jig with the mark on the fence. The rods keep both of the mdf pieces aligned. I spread the jig apart so that I can have access to the jib screws. With the screws loose and the knives in place, I rotate the cutter head slowly. When the knives get close enough to the magnets they will pull them up to them. When this happens I know they are at top dead center. I then tighten the jib screws. My jointer is a three knife head and it takes about 10 min. to replace a three knives. Here's a profile shot of the jig.
Name:	jointer jig 023.jpg
  4. #14
    Dec 2008
    Santa Claus, In
    4,407
    John, I think something is sold just like that
    Rule of thumb is if you don’t know what tool to buy next, then you probably don’t need it yet.
