I have irfanview is there some way to re-size a group of photos all at one time?
Or is there another free down-loadable editor that will?
Thanks
Thanks
I use Easy Thumbnails from www.fookes.com Very easy to use, good options and you can do a whole folder at one time.
Custom built boats and Kits
Bart, in IrfanView, you'll see the Batch Conversion/Rename option under the "File" menu. (Or simply press the "B" key.) From there, you can select the photos you want to resize. You'll also need to select the Use advanced options (for bulk resize) check box. Here's an example of the dialog box that's displayed:
Click the Advanced button next to the check box to open another dialog that will let you set the new size of the photos. From there, it's pretty self-explanatory, but let me know if you have any other questions.
PixResizer lets you do singles or however many you select (or click "select all" button). It is simple, very fast and free.
Enjoy,
JimB
VOTING MEMBER
