Results 1 to 10 of 21
Thread: Frameless Cabinets
    Dec 2008
    Santa Claus, In
    4,779
    Frameless Cabinets
    If a person was to build frameless cabinets, what type of hinge would you recommend? I might try making a couple and have no idea about the hinges.
    5,321
    I like the Blum 35mm full overlay. Fully adjustable in six directions, and easy to install (assuming you have a 35mm forstner bit, but a 1-3/8" will do in a pinch).
    Dec 2008
    Santa Claus, In
    4,779
    Thats a start Jim. hate doing something I have never done.
    13,361
    I think you can find some 'kits' that have a 35mm drill bit and drill guide pretty inexpensively. You want to make sure you put those 35mm holes in the right place...
    5,321
    If you've got a drill press with a fence on its table, that's all you need. The edge of the 35mm hole needs to be 3mm (1/8") from the edge of the door. That spacing works with every Blum hinge I've ever used.
    Dec 2008
    Santa Claus, In
    4,779
    Got it thanks
    May 2011
    So. Florida
    268
    Thomasville, GA
    5,994
    I think you can find some 'kits' that have a 35mm drill bit ...
    A 1 3/8" Forstner bit works fine. Divide 35mm by 25.4mm(1") = 1.378" - close enough to 1.375 (1 3/8) to work perfectly.
    Another option, if you use inset doors is a simple pin or knife hinge. I did that on a cabinet for our family room several years ago and put magnetic push-push catches at the top. Looks great and works just fine.
    Bill Arnold
    Oct 2009
    Dennison, MN
    512
    Quote Originally Posted by Steve Southwood View Post
    I'd do a euro hinge.
    This is from memory so I might be way off here.
    With Blum, if you drill the cup at 20.5mm on center from the edge, and use a straight armed hinge, you want to be using a 6mm mounting plate to get a 5/16" overlay. That'd give you an 1/8" gap on a 3/4" partition.
    I rarely do anything frameless, but I do use frameless hinges and mounting plates for doing inset stuff with a faceframe. I use a full crank hinge, and vary the mounting plates depending on what the pocket from the edge of the faceframe is to the partition. Also requires some thinking ahead when doing cut out and machining decks.
    "Do, or do not. There is no try."
    -Yoda
    Oct 2009
    Dennison, MN
    512
    Whenever I read on of these I always think its too bad no one on here lives close to me. I'd let you drill them with my door machine for nothing.
    -Yoda
  1. Frameless construction question
    By Julio Navarro in forum General Woodworking Q&A
    Last Post: 01-09-2013, 08:27 AM
  2. Best frameless hinge
    By brandon bozarth in forum General Woodworking Q&A
    Last Post: 08-10-2011, 01:30 AM
  3. Mappa burl cabinets....Phase II update cabinets installed
    By Alan Bienlein in forum Flatwork Project Showcase
    Last Post: 05-23-2009, 06:15 PM
  4. Cabinets and SU
    By Gregory Hairston in forum Designs, Plans and Sketches
    Last Post: 12-09-2008, 12:28 AM
  5. We have CABINETS!
    By Don Taylor in forum General Woodworking Q&A
    Last Post: 11-26-2007, 11:44 PM
