Results 1 to 10 of 10
Thread: bathroom+concrete=what kind of flooring?
    Monroeville, IN(Fort Wayne)
    111
    OK so I have this new shop/barn/storage/guest house building that has concrete with radiant heat through out the whole building, what type of flooring can I put down for the guest bathroom?
    my goal in life is to be as good a person as my kids think i am
    life is short, even in it's longest days
    Kevin.....I dont' know what to advise but I'll tell you what I wont' use. I finished a bathroom in my basement and put down a no-wax vinyl. Then we had to put down throw rugs because if you stepped out of the tile shower with wet feet.........it was slicker than some of the mountains we've skiied in the past. I'm also glad I put porcelain tile down in the shower floor rather than glazed tile like I put on the walls of the shower. The two match in color but the porcelain doesn't have a glaze on it and it's not slick. It is a lot easier on us when we have guests, especially our aging parents, knowing that they won't slip and fall.
    17,515
    another in favor
    of non glazed ceramic tile. the slipping can be a very bad thing. had vinyle and needed the rug which can be another route but use rubber back rugs. try to get a lady's point of veiw they tend to look at things differntly than we do
    Monroe, MI
    470
    We had a tile floor in the back entryway and 1/2 bath of our old house in a wing that was on a slab. Concrete would make a very stable base for tile.
    Steve Clardy Guest
    Another for ceramic tile. We used the rougher, textured stuff
    111
    I thought there was something about not putting tile on concrete, not sure where I heard that or why I thought it
    The Heart of Dixie
    4,268
    Showers are built over a concrete bed. Done all the time. I have done two of them.
    Custom built boats and Kits
    30,225
    Quote Originally Posted by Kevin Brown View Post
    I think concrete is probably one of the best substrates for tile available. As Jeff mentioned, it's done all the time.
    yup, tile is usually laid over concrete....durarock and hardi backer are the "low rent" alternitive to a real mud job.....when tile is installed correctly over a wooden subfloor a very stiff mixture of portland and sand is trowled into stucco wire then thinset is applied to the concrete....optimally before it`s completely cured, and the tile set......if the floor is virgin then just troweling on some thinset and plopping down your tiles is fine....if a sealer has been applied it should be completely removed prior to applying thinset...tod
    111
    OK well thanks everybody, tile it is!
    still don't know where I came up with that
  1. Concrete Mesquite Stump
    Last Post: 04-14-2012, 12:43 PM
  2. Concrete Counter Top
    Last Post: 08-31-2010, 01:19 PM
  3. Concrete Counter Top Tips?
    Last Post: 05-24-2010, 02:20 PM
  4. Concrete question
    Last Post: 06-17-2007, 08:58 AM
  5. Engineered Flooring Over Concrete
    By Rob Bodenschatz in forum Carpentry and Construction
    Last Post: 03-15-2007, 05:07 PM
