Results 1 to 10 of 21
Thread: Shop Security questions - Long
    5,175
    Maybe not totally off topic, but I don't where to put it elsewhere.
    The large free standing building I call shop -24' x 36' - is far enough away from the house that I am concerned that I cannot hear someone lurking about.
    Concerns are that methhead robberies are notorious in this community. I do a bit traveling, leaving the cat in charge. Hopeless, I know.
    Pertinent information:
    - One double wide overhead garage door on an opener
    - One 32" 'people' door with deadbolt
    - Two 4' x 4' slider windows on adjoining walls, one of which I cannot see from the house.
    - This is a rental property - want something I can take with me.
    - I have an old [read slow] laptop that I can dedicate to this project, if need be.
    - Or a newer, faster desktop I am not currently using. Would need battery back up though.
    - Distance from shop to house ~120 feet.
    - Brain of the security system can live in the shop, but I would like an alert, either via phone or
    email
    - Local response to alarms is measured in hours, so not interested in paying for a 'service'
    What I will do is to install interior solid (plywood) shutters on the windows to stymy curious eyes.
    Features I'd like:
    - Motion detection alerting unauthorized entry
    - Disguised cameras, motion detectors, mikes, etc.
    - Recorded unauthorized activity, sufficient to be useful to law enforcement
    - Wireless communication
    - Powered and/or monitored by a laptop - built in battery power, in the event commercial power
    is interrupted
    How you can help:
    - Websites to check out
    - Examples from your own systems
    - Overview of what all is needed - help design an intelligent system
    - Should an audible alert sound as well, knowing they are generally ignored?
    Not necessarily looking for the cheapest solution. To replace what is in the building would top $60K, without the car or bike. And yes, it is insured. But, so what? It never is for full replacement value. That is another battle I can do without.
    17,475
    well carol this wil be interesting to see what comes of this, i checked into a security service after i got broke into and like you say its nothing but paying for someone to get there to late.. the audible alarm would deter most, if you hear it. but then your putting yourself in danger are you ready for that? i am from a bad neighborhood as well and now the mind set is different.. i had many chats with out authorities and the prime thing was locks to make them break into which cause us more damage on top of the loss you wil have.. lights help but makes it easier for them to see. there bottom line was that hope for the best and dont advertize what is there.. in my case, i hadnt it was just something to do that night by the perps.. and as for insuring, well plan on 50% and less unless you have total replacement then its depreciated by age and you need to have everything listed right down to the last bracket or base for a router..
    10,604
    Check out Harbor Freight Carol. They have lots of security equipment thats really inexpensive. I don't have a security problem but I put one of their driveway alerts in my driveway to let me know if anyone drives or walks up my driveway. Let's me know when the ups guy is here
    Bellingham
    2,450
    I think you need the right cat. Not like the one on the inside, more like the one on the outside. Just lock him in the shop when you leave.
    17,475
    or the back up down by the lake would deter most crooks
    The Heart of Dixie
    4,268
    I would start with outside motion sensing lights. Cheap and effective. Everyone knows about them but most thieves are not going to stand around in a flood light and break in at night.
    After that I would buy an alarm panel and install switches on all the doors and windows. I would need to know more but I would consider a motion activated switch and glass break detectors as options. But without seeing you building that might not be needed?
    Then you have to think like a thief and look for other ANY other possible way into the building other than doors and windows and protect those. Don't over look the obvious either! A cinder block building it easy to knock a hole in the wall for example. Motion detectors are good for things like that but they do false alarm sometimes.
    Tie those into a Loud siren mounted out of sight! You don't want it to where they can see and disable it. You can do that yourself for less than $25O if you shop around and it will stop most problems. You can add monitoring if you want but I am not sure it is worth it. If you have a neighbor that will call the police then probably not.
    Lot of higher tech options around, but best bang for the buck is a loud alarm to scare them off. Not many will hang around once an alarm starts screaming.
    Custom built boats and Kits
    5,175
    So, suggestions include drilling padlock holes in the garage door track and installing padlocks when I'm gone, installing a piece of steel behind the deadbolt on the people door, installing the inside wooden shutters on the slider windows, use motion detectors to light up the exterior and activate a loud recording of a vicisous dog within, and leave dog dishes, dog poop, and chewed up dog toys around the yard.
    The more exotic digital devises can come later. This is a beginning.
    Still am open to information on designing a digital monitoring/recording/alerting system. Thoughts?
    North West Indiana
    6,099
    For the digital/recording so you know who it is and when it happened. This company seems to have many options at many price ranges.
    http://www.northerntool.com/shop/too...atchallpartial
    Jon
    Central PA
    638
    You could do like they do on construction sites and hang your valuables from a crane, just screw an eyelet in your roof and hoist the whole shop up about 50' in the air.
    NH
    4,012
    Quote Originally Posted by Dave Black View Post
    Ah the old crane trick.........Just makes it faster to load on the truck. And ya get it all in one shot
    If I am not mistaken in order to use any of the video footage against the perp you would have to post in plane sight signs warning that they are being taped. Lots of people find that just the sign is enough to warn off most would be robbers.
    Stupid hurts.
  1. HDMI Connections Monitors Security Systems...... I've got some questions.
    Last Post: 12-24-2013, 07:47 PM
  2. SHOP TIME.......AGAIN- AND A TRIBUTE TO A DEAR FRIEND- LONG
    By Karl Laustrup in forum Off Topic Discussion
    Last Post: 11-23-2013, 04:35 PM
  3. Shop Security
    Last Post: 01-10-2013, 03:13 PM
  4. Shop built saw vise (long)
    By Dominic Greco in forum Handtool Project Showcase
    Last Post: 10-30-2009, 09:35 PM
  5. After two more long nights in the shop......
    By Mike Heidrick in forum Flatwork Project Showcase
    Last Post: 11-24-2008, 09:21 AM
