Results 1 to 9 of 9
Thread: A major reorganization of my woodworking shed is underway
    Toronto, Ontario, CANADA
    2,332
    Here is the floor plan as it has been for about the last four years:
Name:	Workshed Layout Mar 2008.jpg
    That layout was somewhat cramped but OK until 2011 when I added stained glass
    making to the types of work that I undertake in the shed. Now, that place is
    away too messy and unorganized. This morning I decided to try a reorg of my
    major machines to see if that will help. I'm not quite sure where things will
    end up, but I have made a small start by moving the table saw most of the way to
    it's new location (which will be about where the planer now sits and
    perpendicular to that wall).
    I will need to change some of the ductwork.
    Here are a few photos taken about an hour ago.
Name:	Workshed reorg 01 -small.JPG
ID:	63946 Click image for larger version.
Name:	Workshed reorg 02 -small.JPG
ID:	63947 Click image for larger version.
Name:	Workshed reorg 03 -small.JPG
    If things don't work out, I will replace my jointer and planer with a combo
    machine. I did attempt to do that last year but, if I need to
    do so, I will make a more serious attempt.
    Cheers, Frank
    Bellingham
    2,449
    machine.
    I keep going back and forth on that solution myself. If I could just find the right price 16" combo I would do it. I am not sure a 12" would be enough planer width. I look forward to what you work out. I am in the process (a very slow process), of doing the same. I don't even have a tenth of the stuff you do, but I still feel the need to eliminate the clutter. Good luck Frank!
    5,533
    does this mean you'll be re-issuing the Cd of Frank's Woodshop?
    -Ned
    13,357
    Looking your shop inspired me to re-arrange a little bit today in mine. All I did was basically swap the location of the tablesaw and bench, but what a difference in made in usability. My saw used to be close to the wall, so I'd have to move it anyway for long pieces. Just so happened I was making some custom maple moulding today and needed the extra length.
    Thanks for the inspiration!
    2,332
    Quote Originally Posted by Ned Bulken View Post
    Ned, I doubt that I will do that. I am in the middle of doing research and some wrting of a "real" book (not connected to woodworking) and don't really have the time to spend on more updates to "The Story of a Woodworking Shed".
    Cheers, Frank
    2,332
    I have now moved all the machines, etc. into their new locations. Here is the revised layout plan:
Name:	Shop Layout 2012 Jan.jpg
    Its still more crowded than I would like, but I do have better access to everything. The machine that is really hard to place is the jointer. It interfers with every "perfect" layout that I can think of.
    Now, all I need to do is to tidy up the place. I expect that will take at least 10 hours.
    Cheers, Frank
    2,332
    The reorg didn't work out well, so I sold my joiner and planer. See the thread: http://familywoodworking.org/forums/...this-afternoon
    Cheers, Frank
    3,134
    Wow Frank Flat top city. How many benches do you have permanently set up? When I get back into a shop which I hope will be bigger than my last shop. "Your shop size would be a palace" I'll have 1 bench, 1 assembly table, 1 out-feed table for the table saw [ & a wall mounted spring loaded pile-it bench close to the entry door when filled to a predetermined limit it will fold down dumping everything on the floor to be picked up & put away 25 lb limit ] the crap doesn't pile to high this way you see & it falls in the doorway so it has to be picked up. The assembly table will be a light duty torsion box on top of notched plywood support pieces that slip together like this + that come apart & everything hangs on the wall when not in use. I know you must have some reason for the DC to be where is. I would have put it in the far back corner opposite the wood stove if there is enough room. I've always found that having the band-saw within a few steps of the bench to be very handy. Also my preference is to have the table-saw, planer & jointer all running in the same direction for very good reasons.You have 154 sq. ft. more shop space than I had in my old shop & less tools & less room to turn around, This proves that the more space we have the less room we'll have to actually work in because of what we try to pack into the area. How high are your ceilings? A shelf around the perimeter 24" deep & 1' or more down from the ceiling will store a lot of stuff .
    2,332
    Four permanent benches and three more temporary ones. I guess that's a lot, but I always seem to have them filled.
    It sounds like you will be making good use of your space.
    That would be too long a run. I try to keep the machines as close to the DC as I can.
    Good advise!
    The ceiling height varies because of the sloped roof. I do have shelves near the ceiling in several places.
    Cheers, Frank
  1. Steel shed vs wood shed
    Last Post: 01-04-2011, 02:37 PM
  2. reorganization in progress
    By Mark Kosmowski in forum Shop Tours
    Last Post: 06-13-2009, 02:56 PM
  3. Major Boomer Gloat (non-woodworking)
    By Lee DeRaud in forum Off Topic Discussion
    Last Post: 02-24-2009, 03:02 AM
  4. Tour of Frank Pellow's Woodworking Shed -November 2008
    By Frank Pellow in forum Shop Tours
    Last Post: 12-19-2008, 03:02 PM
  5. New bench underway
    By Mike Gabbay in forum Flatwork Project Showcase
    Last Post: 03-01-2007, 10:27 PM
