Results 1 to 10 of 14
Thread: Woodwright's Shop - 2011
    Bellingham
    2,449
    I got this from a blogger and another forum, last seasons airings of The Woodwright Shop is now on the PBS website for viewing.
    http://www.pbs.org/woodwrightsshop/v...100/index.html
    3,134
    Oh Goody!!!!!!!!!!!!!!!!!!!!
    13,357
    That roubo bookstand looks nice and tricky. Might make for a nice Ipad stand...
    May 2009
    Syracuse, Nebraska
    669
    It's easier than it looks, the only hassle is sawing it after carving the knuckle joints. I'll see if I can get a pic of the one I made and gave away. It was made of basswood for ease of chiseling. Only took about three hours from layout to finish.
    And thanks for the link Bill
    Jan 2012
    Gonzales, Louisiana
    115
    Quote Originally Posted by Roger Newby
    I'd love to see the pictures. That would be a fun project if for nothing more than practice cutting knuckle joints!
    12,247
    Brent i should have known you would get hooked on that stand. So did i. To the extent that it caused me to start a bow saw (which aint finished yet..) to be able to do a total Roubo stunt and use a single piece of wood to get two stands. I am gonna make two out of a slab of Mi walnut. They look too cool for sure. I am dying to see that knuckle joint work. Will post pics in 2013 when i get done
    May 2012
    Texas
    5
    I saw the 'Roubo bookstand' segment and Roy made it look easy.
    I ordered a nice piece of walnut and started chiseling the knuckle joints like Roy Underhill explained.
    But after completing one side of the knuckle joints I turned the board over to chisel the other side and
    was disappointed when I cracked the board into two pieces. Lucky for me I had to trim a piece off the
    walnut board I ordered because there was a small crack in the top right corner. After trimming it left me
    with a "practice" piece about 4 1/2" X 6" but like I said - it cracked into two pieces. So, I still have a good
    chuck of walnut for my Roubo bookstand but now I think I should practice on some other "wood."
    Basswood = easy chiseling?
    I wasn't able to find a paring chisel as thin as the one that Roy uses on his show.
    Did I make a mistake by chiseling one side completely and then doing the other side?
    Quote Originally Posted by Roger Newby View Post
    12,247
    Carlos did your board have any cupping? or did you have anything caught under it when you were chiseling.?
    Sent from my MB860 using Tapatalk 2
    May 2012
    Texas
    5
    No cupping and the board was fully flat on my wooden workbench while chiseling.
    I asked my neighbor and he said that maybe I need to just take off a little at a time and
    not hit it so hard. I am a complete newbie and this is my first wood project. So I am
    chiseling softer (lighter taps) on my yet even smaller walnut practice board and it
    seems to be going pretty smoothly. But if it cracks I most definitely will try some other
    softer wood. At least that is my current plan. Thanks.
    30,008
    Sorry to go off topic, but Carlos, depending on how and where the board cracked/broke, chances are it can be glued back together, and the repair will quite possibly be nearly invisible. As an example, here are some before and after photos of a redwood platter I repaired and refinished a couple of years ago:
    The Break - Front
    The Break - Back
    Glued, Sanded and Ready for Finish
    Fixed - Front
    Fixed - Back
  1. 2011 Toy Swap
    By Steve Southwood in forum Giveaways, Contests, and Swaps
    Last Post: 08-12-2011, 04:06 AM
  2. first project of 2011!!!
    Last Post: 04-15-2011, 08:13 PM
  3. About the 2011 FW Calendar
    Last Post: 01-16-2011, 09:00 PM
  4. Elia Bizzarri on Woodwright's Shop
    By ken werner in forum Off Topic Discussion
    Last Post: 10-15-2010, 02:19 AM
